Steering Column Diagram
Hello, I was checking out my truck and found out the cruise control and the horn do not work. The column had some up and down play before disassembly. I pulled off the cover on the steering wheel and all the wires from the horn and CC were all twisted and broken (not connected to anything). I pulled the steering wheel and removed the column shroud, turn signal switch and ignition swich. I can see a 3 pronged connector inside the column but there is no connector on the wires from the horn/CC. The shaft has internal threads where the steering wheel is bolted onto the shaft but no external threads for the lock plate tool to attach to. It looks like someone has tried to do some repairs in the column but I don't think they were done correctly. Does anyone have a diagram/parts breakdown of the internals of the column?
Thanks
James
Thanks
James
mikeceli
07-19-2016 03:51 AM
papazig4726
02-19-2015 12:22 AM
Old Brown Truck
11-13-2014 01:11 AM
daggerNC
18
11-07-2004 07:28 PM
