Fuel in the coolant system
Old 03-21-2009 | 05:31 PM
bigdummyford's Avatar
bigdummyford
Well I noticed that i have about 2 inches of what appears by smell to be fuel in my coolant system. Now from reading prior postings, I understand it the injector cups? I also was told by another guy its some kinda valve, so anyhow anyone pint me in the right direction as to what it is, or what it might cost to fix up? and can i do it myself how involved are these procedures. Yous guys' help is greatly appreciated.
Old 03-21-2009 | 06:31 PM
jwhitetail's Avatar
jwhitetail
Other's will chime in on this, but i think the only way it could mix with the coolant is the passage in the heads. There might be other ways, i not for sure.
Old 03-21-2009 | 07:01 PM
guzzle92's Avatar
guzzle92
Injector cup
Old 03-21-2009 | 09:58 PM
05chop's Avatar
05chop
Yep injector coppers! Better change all of the injector cups and make sure you use some good soap to flush out radiator.
Old 03-22-2009 | 05:25 PM
bigdummyford
ok I fugured it was the injector cups, but how hard is this to do? I have had my turbo off, I am sure its not too tough to dig just a little further. how hard is it to replace the actual injector cups
Old 03-22-2009 | 09:42 PM
05chop's Avatar
05chop
Choice is up to you if you are going to replace all eight cups.If not when all injectors are out pressure up the radiator to 10-15 psi.Look into all eight holes you will see copper sleeves. Injector Sleeves can crack or pin hole or seep water near the tip of the injector copper.Tools needed are a very large tap which you will cut threads into the cooper then remove the sleeve with a small slide hammer.New sleeves are swegded into the cylinder head with another tool thats shaped like an injector tip to hammer into position.Then there is a final tool to cut and clean up the injector bore.Not a lot of fun doing this humped over with engine in truck though.
Old 03-24-2009 | 09:37 PM
bigdummyford
Ok I just dont have the time or weather to do it myself, i dropped my truck at a dealership tonight and they will call me with some results by midnight if they can. What dealership works till midnight? MANEY INTERNATIONAL in Duluth, MN thats right forget the half a$$ ford dealerships that hve no clue aboutdiesels, i took it back to the source. I'll let you know how this worked out for me.
Old 03-25-2009 | 11:48 AM
jwhitetail's Avatar
jwhitetail
big i think you did the right thing, there's some shop's around here that are good on diesel. Let us know how it went.
Old 03-25-2009 | 09:39 PM
bigdummyford
ok here we go, so i got the bug since they have the injectors out to go ahead and do some upgrading, after an awesome half hour talk with bob at dieselsite, he set me straight to what I NEEDED! So what I am now doing is f course replacing the cups but i think i might be getting robbed, the price for labor went from 850 ish at drop off to 1300 this morning to 1500 possibly since they have to remove the AC! I call BS but we will see. so back to my needs, going with alliant AC singleshot injectors, dieselsites regulated return system, and a tuner that will learn my computer to fire the singleshots right. added bonus, its a tuner so i get lotsa power options!
Old 03-25-2009 | 10:46 PM
danskool's Avatar
danskool
Go Bills !
parkland
6.4L Power Stroke Diesel
05-08-2013 08:42 PM
speedtrapp
10-10-2012 09:24 AM
444dieselrod
Bio-diesel, Propane & Alternative Diesel Engine Fuels
09-07-2012 11:01 AM
j250hd
08-18-2011 04:21 PM
DieselE
11-18-2009 10:52 AM
