What is the load bearing weight of the tailgate
I forced the issue with a salesman at my local dealer, Family Ford in Netcong NJ, and after spending a good amount of time in the offices, he came out with a sad face and said 100 pounds. Apparently Ford doesn't want to touch the issue.
I also regularly ride a 600lb atv up a ramp thats on the tailgate, and no problems yet.
Beware of tailgate cables, I've had ones that were just about rusted through, but could not see it through the casing.
Don't get overly confident with the plywood .... its bending, etc
My back tires on the Arctic Cat rest on the tailgate when traveling too.
I was loading big rocks for a water garden on my tailgate on the F150 and stopped when I couldn't put any more on it, because I didn't have any room. We then loaded a friends Tacoma pickup, and his tailgate came crashing down and ruined it with just a couple of these rocks. I still tease him about it!
The Ford's are workhorses. End of Story.
Just a clarifying opinion; plywood isn't going to do you any good until (some portion) the load is past the hinge point. While loading (COG behind the gate pivot point) it will all be on the gate and cables- or at best, wherever the plywood's aft point of contact is, which will still be negligible until the load is past the hinge line.
Just envision a fulcrum and you'll see what I mean.
Part of the weight of the load will be on, at least (because of bending), the rear-most edge of the pickup bed floor. I don't think its negligible.
No??
I cautioned against being overly confident because the plywood would be crushing. The plywoods crushing and resistance to bending makes calculations difficult.
No??
Just because the manual says 150lbs doesnt mean thats the max. Thats just the max ford wants you to put on there.
