High Flow Cats Pros/Cons
Old 01-14-2003 | 12:25 AM
Explorer_Lightning Wannabe's Avatar
Post High Flow Cats Pros/Cons
Can anyone tell me the pros and cons of replacing my factory cats with high flow cats? Im currently running a Flowmaster 40 series on my 4.0 Explorer but still looking for more power. Are High flows the way to go? Thanks.
Old 01-14-2003 | 10:10 PM
1984_355w's Avatar
1984_355w
If you HAVE to run cats the high-flow ones are the way to go. Less restriction=more power/gas milage.
Old 01-14-2003 | 10:20 PM
How will this effect the sound? And are they still emmissions legal?
Old 01-15-2003 | 09:28 PM
mjb1962's Avatar
mjb1962
Somewhat louder. Mine passed the IM 240 emission test here in CT. They look under the vehicle with a mirror to inspect. Not a big power gain unless the originals are plugging but it is noticeable.
Mark
Old 01-15-2003 | 09:55 PM
MustangGT221's Avatar
MustangGT221
The high-flow should pass an inspection just fine. I put one on mine, but still have 1 stock cat. It's a 3" in and 3" out from summit, 80 bucks. Catco brand. Good cat, no problems but I didnt see much for a power improvement even though I know it flows better. 5-10hp is hard to feel so i'm sure it's just my judgement. The 1st cat is probably alil plugged anyway. There are no cons that I can see.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Justin - One Happy FTE Member
Old 01-15-2003 | 09:56 PM
ckybufallo's Avatar
ckybufallo
