Park no start
Park no start
Hi guys,
Haven't been here in while been real busy losing money and all. Anyway
truck has been giving me trouble with not starting until I play with shifter in the Park position then it will start like it finally activates a sensor or switch that tells the truck it's in park position. I don't know what this thing is called or the procedure for replacing it,was thinking someone here probably knows exactly what to do. thanks in advance Randy
This fixed my problem a couple of months ago. Had to shift to nuetral a couple of times to start and a lot of play while moving the lever. If you jiggle the shifter handle while looking you will see the two torx screws.
Guys,
Found the torxs screws and they were indeed loose, adjusted the barrel nut so the the indicator is on but still having problems. Shifting to neutral does not work either. Think it may be my ignition switch hard to tell-it is so erratic-usually will work after I shut off the truck but after it sits at night then I have to fool with shifter and Ignition switch to get her to fire. Thanks Randy
Where is the barrel nut? Is it on the linkage to the trans or is it the wire that just controls the indicator location in relation to gear selection scale?
Thanks for contributing Randy
37 Ford guy
01-15-2013 12:03 PM
ssj7kids
10-04-2012 08:22 PM
