'79 F-250 Lift questions...
Old 12-11-2008 | 03:54 PM
mikeberman04's Avatar
mikeberman04
I'm planning on lifting my '79 4x4, i would love any info from guys who have already done it.... info on anything, as i know not much about it.
I was planning on going 4", but want to know if there is much of a difference between 4" and 6"? From what i've looked into, its pretty much just blocks and new shocks right- what about leafs? Does it change any angles to where i need new drive shafts, pitman arms, etc?
Like i said, i dont know much about lifting and am open to any and all advice i can get. Thanks a ton ya'll!
Old 12-11-2008 | 06:14 PM
4x4 Bart's Avatar
4x4 Bart
Rough Country sells a 4" for 771/2 to 79 f250 after that you have to modify kits made for other years. Do a search (above) on "lift" or "super duty 6" lift" and I think you will find a detailed past thread on this subject.
Old 12-11-2008 | 06:31 PM
ncl's Avatar
ncl
Depending on your budget I would get a kit that has it all which would include the following:
New rear springs with u-bolts and spring bushings
New front springs with u-bolts and spring bushings
New shocks front and rear
New Pitman arm
Dont forget to install extended brake lines also from frame to axle
A 4" wont require any driveshaft changes a 6" most likely will.
The reason I say a kit with new rear springs instead of using current springs with blocks is by running arched springs you dont need the blocks and you get less axle wrap that way. Many companies make complete lifts with front and rear springs you have to specify most of the cheaper kits come only with front springs and rear blocks, Never run lift blocks in the front. Good luck and post some pics of the finished product. Other compenies that make complete systems are superlift, skyjacker, also Jeff's Bronco Graveyard sells complete kits as well.
Old 12-11-2008 | 06:32 PM
mark a.'s Avatar
mark a.
I think Sky Jacker still makes a 6" kit but it wouldn't have the drop pitman arm / drop draglink. You would have to buy that seprately.
Old 12-12-2008 | 12:24 AM
skunktruck's Avatar
skunktruck
Yes Sky Jacker still makes a 6in lift as stated before you will have to buy a drag link and a pitmin arm. and for sure spend a little extry for rear springs. I went the cheep way and got blocks...yeah what a mistake that was now i bought the rear springs. I never had to mess with the driveshafts however i would like to tilt the front axle a bit as to straighten the front driveline out. but thats my 2 cents
Old 12-12-2008 | 06:52 AM
Tha_Stepside's Avatar
Tha_Stepside
Dont forget about BDS, good quality stuff.
Old 12-12-2008 | 09:12 AM
Don S.'s Avatar
Don S.
I have a question to add, if one was to have a 3" - 4" lift, what would one look for for a drop pitman arm? Would you want the same drop like a 3" - 4" Drop pitman arm?
Old 12-12-2008 | 09:25 AM
79schaefer's Avatar
79schaefer
On the F-250s it is not a dropped pitman arm, it is a drop drag link. This drag link is adjustable also. The dropped drag link that is available is for the 4-6" lift.
Steve S.
To many to list.
Old 12-12-2008 | 04:16 PM
mark a.'s Avatar
mark a.
When I had a 6" lift, I had a drop pitman arm & a drop drag link. If you are going to go 6" I'd go to crossover anyways. Push pull isn't any good after 4". Not that it was ever any good though.
Old 12-13-2008 | 09:57 AM
skunktruck's Avatar
skunktruck
hey mark a. how had is it to convert from (push-pull) to cross over steering?
Old 12-13-2008 | 05:15 PM
mark a.'s Avatar
mark a.
Mine was simple but I have a king pin Dana 60 front. All I had to do was buy the right steering arm & a bar. I already had a drop pitman arm on it so I just turned it 90* & bored it out to fit Chevy tre's.
A 44 you would have to get the steering knuckle machined for a right side steering arm. Some off road co's offer exchanges on a machined knuckle.
It's been a while, but I think I got my stuff from ORU.
Old 12-13-2008 | 05:24 PM
TexasRho83's Avatar
TexasRho83
I put a Rough Country 4" lift on my previous 78 F250 Supercab and it was pretty cut & dry. My kit came with all 4 shocks, front springs, steering block (raises the height of the draglink on the knuckle), and poly bushings. Came with rear blocks but I didn't mind 'cause I wasn't going to use the truck for trails just mudbogs and daily driving. The only problem I had was that the bushings were a little too wide but I applied a little southern ingenuity and they fit fine. I think I spent around $500 and it was worth every penny.
I wouldn't go 6" unless you wanna buy longer brake lines (or detach the mount brackets from the frame) and risk the clearance issues with your front driveshaft and the transfer case crossmember. You're also gonna end up having to upgrade your steering with a taller lift. At 4" your stock steering shouldn't be a problem unless you cut your fenders to put on massive tires lol
