Need Help guys !!
How would you suggest that I check that.... I took an ohm meter and tested from the trailer wire to the frame of the truck ???? Does that make sense ?? So then if you plug the trailer in to the plug and the plug is grounding to the truck... That should do it right >?????????????????
I've also been told that there may be another fuse for the tail lights on the truck that may be causing the problem. One fuse could provide enough feed back through the other to produce the voltage, but when under load it can't produce enough ??? #38 is the fuse for the trailer park light circuit. What about the truck tail lights ??????????? which fuse runs those ??????
The ground pin has continuity to the truck.. the trailer was hooked to the truck.... If I run an extra ground wire from the truck to the trailer will that serve as a pretty good indicator of the grounding circuit ?????
See this PDF for fusing and relays. It's for a 2001 but believe 2003 is the same.
Brake lights and turn signals works fine ! Just the running lights don't work and there's power to the terminal ! It doesn't make sense !
It looks like the 2003 and 2001 fuse panels are different. The numbers for locations are quite different and the lay out is not the same...
Does anyone know if in the 2003 there is another fuse panel. I see the main one under the dash and then a couple little relay boxes behind the airbox area ! My owners manual pdf file doesn't show where the tail light circuit for the truck is ?? This is starting to get under my skin ! There has to be another relay or circuit breaker for these lights that isn't providing the power under load, but will show power when not under load...
Its got me good !
don't know if you can find anything to help in repair manual but here it is
https://www.motorcraftservice.com/pu...20/S3OMAIN.HTM
I FOUND the problem....
It was at the connection between the rear plug and the truck wiring harness.. The brand new harness that I put in a while back had the retaining clip broken.. I guess it was hit by a rock or something. I pulled it a part and shoved it back together and bingo... running lights are working.. I don't know why I was getting power there and they wouldn't work.. but when I pulled that connection apart and reconnected it... they work... Must have been enough of a connection to read 12.4 volts but not enough amperage to light all the lights up when connected.. That was a weird one...!
I connected it up again and taped the living sh#@ out of it so it would stay together... If it happens again... I'll no where to look right away !
Thanks to everyone that helped out with wiring diagrams and ideas, I'll be sending all of you reps that helped out !!
![Drink to That](images/smilies2/party0005.gif)
Russ
![Confused](images/smilies/confused0082.gif)
Russ
#28
#29
#30
