Flowmaster 40 Delta Flow vs. 50 Delta Flow
If you want to go with a Flowmaster I would recommend a FM50SUV or FM50HD. These mufflers have a larger capacity than the delta flow 40s and 50s and will help cut out the drone. I really like Dynomax Ultra-Flo mufflers, they flow like crazy. A turbo muffler would also produce a sound similar to what your looking for.
When I had the ultra flo on my SD I had a lightning style exhaust with the pipes exiting in front of the right rear wheel. It was loud, but interior noise was not bad considering the circumstances. If you are really worried about interior noise, exit the exhaust out the rear of the truck. I think you would be pleased with an ultra-flo when exited out the rear of the truck.
I don't like the dynomax. I have heard it on a couple different trucks and you can barely hear it outside the truck.
A friend of mine had one dumped under the bed and had magnaflow cats. His truck was way too quiet like that. He went with a cherry bomb extreme. The cherry bomb elite may be to your liking.
I would go with the 50 series Flowmaster.
Super 40 or Thrush welded
I have since changed my mind. I'm trying to decide between the FM Super 40 or the Thrush welded. I heard a 5.4L with a Super 40 the other day, and it sounded really good. I've also heard the Thrush welded muffler and it sounds good too. They sound very similar. I don't know if the FM is worth the extra $ if I'm just going for sound.
wildcat99
15
10-31-2007 02:02 AM
