How do I know if I have Limited Slip Differential
I have a 1993 Ford F150 4 wheel drive. I have the numbers from the rear axle, but I get conflicting answers on whether this is a limited slip differential. The numbers are:
S838B
355 882 L03
Does anyone know whether this is limited slip? Thanks.
S838B
355 882 L03
Two ways:
1. Look on your driver's side door jamb--under "axle" you should have a code like "H9N" which would tell you that the factory stuffed a 3.55 Traction-Loc under there, and/or:
2. Jack up the rear end so both tires are off the ground. Rotate one wheel by hand--if the opposite wheel turns the same amount, you, sir, have a traction aiding device of some sort.
FWIW, if you're interested in Ford's breakaway spec, it is 50 ft./lbs. To check, raise one wheel off the ground, set your torque wrench at 50 ft./lbs., and turn the raised wheel by one of the lug nuts. Ford sez to do this with a special tool which poitions a turning hex directly concentric with the axle center, but...
Eddie
Eddie
[font size="1" color="#FF0000"]LAST EDITED ON 27-Feb-01 AT 10:06 PM (EST)[/font][p]OR, my personal favorite: 1)park your truck on some nice, dry asphalt. 2)Fire up truck. 3)depress clutch and rev motor to @ 7000rpm 4)dump clutch. 5)check for dual skid marks (on the road not in your shorts)
If your knuckles ain't bleeding you did something wrong.
'72 F-250 "Hi-Boy" 4x4, Dana 60/HD44, FE390 @ 400hp(purt near!), 4-speed, custom suspension w 4" lift, mud on black.
be careful though, it wont work unless u hold 7,000 for 2 mintues before u dump it to let your tires get ready =)
1985 F-150/351Ho/4wd/6inch with 33's
1979 f-250 429/4spd/5inchwith 36 inch buckshot mudders
on a quiet night your can hear a chevy (lol,you can watch a dodge) rusting away
The numbers on your tag mean the following
355 = 3.55 gear ratio
88= Ford 8.8" rear
L= Limited Slip
So your truck is a limited slip(posi - same thing). If the truck was not limited slip (like mine!) there would be a space where the L is on your tag.
-John
88= Ford 8.8" rear
L= Limited Slip
-John
for a long time i thought i had a limited slip rearend because of that tag on the pumkin. but one day an unwise and unlearned person said to me (take a leak now cause you might wet your pants laughin) that fords suck. i skooled his ##### on that one by doing a brakestand to make his mother cry. but, twards the end only my pass. tire was spinning? what's the deal?
Well, cuz a limited slip is just that, sometimes it won't lock them both up. Thats why God made lockers and spools.
I know this is an old post, but I just bought a 2001 with the 3.55LS, Axle code Is the H9, and the diff take does say LS, But when I make hard left or right turns froma stop, I get the chattering. I had Ford do both rear seals(cause warranty paid) and they did put the modifier in. How long does it take for the modifier to "work" its way in? I looked in the case when they had it open and I didn't see any packs. Are they hard to see? Ford tells me they won't replace them either, because its not a "Safety" issue, sO I was going to do them myself iif need be.
Thanks
Rich
Thanks
Rich
Platinum08
1999 to 2016 Super Duty
12-10-2014 10:39 AM
BikeMaker
01-28-2010 10:41 AM
TedFromOhio
1997 - 2003 F150
01-08-2010 02:19 PM
02, 1993, 355, 88, diff, differential, differentials, differntial, f150, f250, ford, limited, ls, slip, truck
