?'s about flowmaster 40 series
Old 09-23-2008 | 12:37 PM
96 300's Avatar
96 300
Question ?'s about flowmaster 40 series
i am curious of what i should expect my 1996 300 should sound like with the rear cat removed and flowmaster 40
Old 09-23-2008 | 10:40 PM
offroadbronco's Avatar
offroadbronco
a tractor at low RPMs and a ricer burner at high RPMs
Old 09-24-2008 | 07:29 AM
Motorhead351's Avatar
Motorhead351
Look at the sticky.
Then go to youtube.
Old 09-24-2008 | 08:33 AM
96 300's Avatar
96 300
thanks guys 4 the help does anyone know what kinda muffler would give it a decent low rumble and not give it a rice burner tone
Old 09-24-2008 | 06:30 PM
dude100's Avatar
dude100
i took off my muffler off and put on a 3 inch tip on my truck , it sounded like a diesel a friend of mine even asked me if i had swapped the engine
Old 09-25-2008 | 01:51 AM
optikal illushun's Avatar
optikal illushun
it wont sound a like a diesel because there is no turbo to chop the exhaust pulses.
i perfer magnaflow or a cheap raptor turbo. after putting my magnaflow back on with my headers i am not liking it so much LOL
Old 09-25-2008 | 06:33 AM
Motorhead351
Best bet would be a flowmaster 70 or a flowmaster cat back which uses the 70.
It would be extremely quiet but shouldnt give you that upper rpm buzz the inline sixes are known for.
Another option might be to increase the diameter of the pipe, and use an OE muffler designed for a larger displacement/powered engine.
Old 09-25-2008 | 09:38 AM
96 300's Avatar
96 300
I have the flowmaster force 2 system with my rear cat removed and u can barely hear it everyone around here says the original 40 series is what i need and that would be my best bet 4 a good sound but i have also had them tell me u cant get a 300 to sound all that good to how much tone and how loud is the magnaflow
Old 09-25-2008 | 09:42 AM
slick96cyl's Avatar
slick96cyl
I have a 96, with a flowmaster 40 series. Stock cats and so on. I think it sounds very good. I don't hear the "ricer" sound that everybody is talking about. I think it sounds ten times better than a glasspack or straight pipe.
Old 09-25-2008 | 06:11 PM
Heavy_Metal's Avatar
Heavy_Metal
The cheap "summit" brand 3" cat-back I had on mine sounded pretty decent.
Old 09-25-2008 | 09:26 PM
96 300's Avatar
96 300
Well maybe i can get one of the local exhaust shops to let me try out different styles of mufflers till i find the right one
Old 09-26-2008 | 07:53 AM
Motorhead351
Is the tail pipe bolted on or welded? If its bolted, disconnect it and run it like that for a few miles, see what you think. If its welded, see if the muffler shop will cut it, let you drive it a few miles then weld it back. This would give you a rough idea what it would sound like with a 45 degree turn down, it should be a little bit louder.
if you do get rid of your flowmaster 70, feel free to send it to me.
Old 09-26-2008 | 09:21 AM
96 300's Avatar
96 300
Well i got an appointment today at 3 so i will post what set up i go with and i will keep the 70 series just in case
Old 09-26-2008 | 11:13 AM
AbandonedBronco's Avatar
AbandonedBronco
Personally, I went with a Dynomax turbo muffler and did a 2.5" exhaust. I have a carb'd engine, but it should sound a lot the same since I have EFI manifolds.. It sound awesome. A nice quiet tone, but definitely some power behind it. I'd recommend it.
YouTube - 1981 Ford Bronco 300 Straight Six new exhaust
Old 09-26-2008 | 06:04 PM
96 300's Avatar
96 300
Well after trying a glasspack,flowmaster 40,super 40 and straight pipe it didnt take much to make up my mind none of the mufflers had enough level of sound so i just went with straight pipe its a tad louder than i wanted but ive already had compliments on it
