ATS Housing problem.
It's been a while since I've looked at one, but doesn't the big o-ring sits outside that area where it's rough? Not that I wouldn't try and exchange it for one that didn't have a casting flaw, but to your original question, think it would seal ok.
I'm suprised that made it through quality control inspection.
i could be wrong but i dont' think they are countersunk. Looks like a smooth ring around each hole to me. Optical illusion. it should still use the same bolts, so don't think it would be countersunk.
and they work fine?
im waiting to hear back from ATS on the issue. i sent them these pix this morning. we'll see what they say.
and the bolt holes are countersunk. but it looks like theres enough beef there.
another issue that there is, which im sure doesnt matter, is the flange has some sub-par casting. im sure this wont effect performance, since its just a clamp surface, but nontheless....
I would send it back and ask for a better one. I can get particular about the littlest things, but all the bolt holes not having the same amount of material all the way around them and the poor casting inside and out, to me, is unacceptable.
Hopefully they aren't all like that, it's scaring me away from getting one.
Yeah thats why they were backordered for a while, they had to change castings, something of some sort, and now the new ones dont look too good either. I had ALOT of slag on the inside of the outlet on mine, and it took a good 30 minutes with a hand file to clean up what shouldnt have been there anyway. The compressor doesnt get close to that mark on the inside, however be weary of a boost leak from the outer one 'near' the seal. Dont use it at all if you are going to return it, if you install it and then complain they will have a reason not to work with you.
well ATS said that it would be fine. (of course right?). he said that the o-ring will seal that part off and it shouldnt be a problem. they did offer to take it back and get me a new one.
normally i would feel more comfortable returning it and getting a replacement, but since there's a 4 to 6 week backorder on these (and i need it for a trip in 2 weeks) im going to run it and see what happens.
they said that if i have any problems with it post install, they would take care of it.
we'll see how it works.
