Titanium vs ceramic coated headers??????
Seems to me that ceramic headers would dump a lot more heat out the exhaust and keep the motor running a little cooler. Ceramic can reflect and metric ton of heat. Might be a slight drawback though as your exhaust temp would rise, not that it matters a whole heck of a lot if it's routed properly. I wouldn't know for sure though.
JBA offers two coating options, a base polished silver ceramic that is good to 1500°F + and a high heat coating good to 1600°F+ that they call their High Heat Titanium. No, there is no titanium in the coating. The name stuck because of the color of the header, which I liken more to the color of a battleship.
In most all but the most extreme case, the polished silver ceramic coating is the best choice for your vehicle. It definitely looks the best! You would need to use the High Heat Titanium coating on those applications that are heavily supercharged, heavy towing, and any engines with very high EGT's (exhaust gas temperatures). You will notice that some of the JBA headers are only available in the high heat coating, such as late model Ford trucks. This is due to their high normal exhaust temperatures.
For further reading, please take a look at our more detailed article on header wraps and coatings in the TECH ZONE
![Typing](images/smilies2/compute.gif)
chad.deraps
05-03-2011 06:49 PM
1EVILCREWCAB
31
03-10-2008 06:21 PM
