my truck is having some troubles
Alright, I own a 2001 singal cab f-350 7.3L with 114k on it, it is bone stock.
Today I was plowing my driveway, but when i tried to push snow into a snowbank the overdrive light started flashing off and the rpms dropped to about 400 seemed like it was going to stall. Ive read that the overdrive flashing off means transmission trouble but Im not sure if that is it because after taking my plow off I'll drive a mile or so and the overdrive will stop flashing and it will return to normal. It's only when trying to push snow. Not sure if anyone has heard of this happening before, but it would be cool if someone knows something or could point me in the right direction. I plan on bringing it into the shop monday to see if they cant pull some codes and fix it.
Welcom to FTE!!!!
I hate to install un-just fear but I'm pretty sure that means the overdrive unit in your trans. is going out... If its only under heavy load you might get away with sevicing it. Do not quote me I am not a pro around here nor do i have an automatic. Dont worry one of the pros will be here soon and tell you the truth.
1: Welcome to FTE.
2: There is a guy near me that runs a fleet of about 15 plow trucks running from f-350s to single rear axle MACK trucks with big plows on the fromt. The guys he has burn transmissions out on the little Fords all the time doing exactly what you said you were doing.
Hope you can get it straightened out!
I brought it in today, they couldn't get it to happen so I told them to chain it to a tree and put stress on the tranny, they said they would do it first thing in the morning. I will keep you updated
p.s they said to just put it into second and let the motor take the stress when plowing. (Im 18 and it's my first truck so just letting everyone else know so maybe it could help future problems for somebody else)
They wouldn't chain it to a tree.. So im just going to get the tranny flushed/new filters bring it home see if that doesnt help any. If not I'll bring it down friday and get it to act up for them. Also the only stored code there was, was a speed sensor so, hopefully i can get this thing fixed without much trouble
Alright so, after a week and a half at the shop, they have told me my alternator is bad and im pissing tranny fluid from between the transmission and t/c. I'm having the seal replaced this week, and then i'll buy and put in the new alternator so hopefully this will solve all my unwanted problems
