speedometer needle "jumps" while driving
Old 03-02-2008 | 11:16 AM
F100classics's Avatar
F100classics
I have a 1993 F150 that has a problem with the speedometer needle acting erratic. Once you get over about 20 mph. the needle on the speedometer begins to bounce between your true speed and 5-10 mph under. I changed the vehicle speed sensor at the rear differential. The problem still exists. Is a bad ground to blame. Either at the speedometer or the speed sensor. Would this problem effect the engine's management system also. I seem to be getting worse mpg. and pinging on hills.
Old 03-02-2008 | 04:19 PM
Franklin2's Avatar
Franklin2
Yes it might affect the engine management system. I would follow the wiring from the sensor and check it for corrosion and bad connections. Also, is the mechanical condition of the rearend ok? That could affect the ability of the sensor to read.
88_F0RD
15
12-04-2016 12:45 PM
Bucky623
1997 - 2003 F150
09-13-2016 02:56 PM
49f3dls
05-25-2016 07:37 AM
millerliteliker
02-01-2016 04:27 PM
captain1997
1997 - 2003 F150
11-27-2015 11:01 AM
Quick Reply: speedometer needle "jumps" while driving
