Can I go from a 400 to a 429 or 460
I just purchsed another truck this one is a F-100 custom 6 .5 foot stepside with a 400 engine and C-6 trans in it . Will a 429 or 460 bolt right in ? It has Factory A/C and I am not sure but the buttons on the steering wheel is that Cruise control ?
http://cgi.ebay.com/ebaymotors/1977-...em120220896801
You need different engine mounts,engine accessories (bracketry) for 2 things,
The 460 should swap over cheaper.
The 429 will require a different torque convertor as the crankshaft to TC is different.
A Cruise control swap over will require the special 429/460 engine C/C assembly.
Cruise control involves a special harness beyond the steering column.
I can explain in detail if need be.
ok so I need all the brakets with the engine . The engine mounts along with the flywheel . If I already have cruise control in the truck I need the harness that goes with a 460 rather then the 400 .
Would this work for a doner truck and do they sell the harness as an after market piece .
http://albany.craigslist.org/pts/572245297.html
Flywheel ?
You said you have a C6 automatic.
You have to state what year 460 you have
On a 429 the back end of crankshaft where the nub of the Torque convertor fits when mated is TOO small for the T/C of the 400 to fit.
It may fit the older 460.
Cruise control: You need the 460 engine bracketry for attaching the actuator as it mounts different than on a 400.
Illustrations to follow
[QUOTE=Mil1ion]Flywheel ?
I didn't have any problem mating C6 to the 429 when I swapped out the 400
first today
33
09-23-2009 07:11 PM
bicyclemonkey
09-14-2009 11:07 PM
mabigredtruck
09-14-2009 02:35 PM
havi
08-29-2008 07:42 PM
