Dana 44 u bolt size
Unless you have flipped the u-bolts, your ford uses a square u-bolt that doe not actually go around the axle tube like a round u0boly would. Your only concern is that you buy a replacement u-bolt that fits a three inch wide spring, and are long enough to reach trough the mounting plate under the axle.
Front u-bolts do not capture the axle tube like rear ones do, they actually fit in front and behind the axle tube, if that makes sense.
Take a good look at yours, and you will see exactly what I am talking about.
SuperDuty93
07-04-2016 06:46 AM
