Wiring for the Stop lights, cruise control and hazzard lights(rear)
Wondering if anyone could tell me where to look for this circut underhood as the is no power to circut at the fuse box... I have a 1990 F150 custom 5.8L E4OD
Any help would be greatly appritiated...
Thanks in advance,
Mark
Thanks in advance,
Mark
Thank's for the response, after a few hours out in the cold and snow I found a fusible link that was dead and fixed it up... but unfortunately I still have no brake lights, cruise control, or rear hazard lights... the turn signals in the rear still work, but not when you have the hazzard lights on, and the brake light's dont work either.... allready installed a new brake light switch as I was a block from the part store when I was told I had no brake lights and picked one up...
I am assumeing that the wiring under the truck should be OK as the turn signals still work...
thank's
Mark
thank's
Mark
now that you have power to the circuits the turn signal switch maybe bad
turn, brake, and hazzard lites all use the same element in the bulb
all are controled thru the t.s. switch
this may be where your problem is now
it is a common thing to lose a function at this point
the hazzards will over ride the turn signal
unsure if they over ride the brake but I dont think so
I would not asume that the wiring is good, I just had a similar problem in my dad's 86 f150. The cause was a bad ground. I asumed that power was the issue and spent two hours on it until i put the truck in reverse and everything lit up. The ground was bad in the harness and other wiring was brittle so I rewired the taillights. best of luck.
OK well those will be my next places to check once daylight rolls around again and hopefully the snow stops fallin... My reverse light work fine but it doesn't light anything else up... thank's for the advise and we see what I find tomorrow... doin a diag on elec sucks when it's cold and snowin....
Thank's again,
Mark
Thank's again,
Mark
Problem Solved!!! The brake light wire in the turn signal switch was to blame.... a few to many years of flexin... I also noted that my RW ABS light no longer comes on above 60 or so km/h, didn't even think that they were connected problem but know I know for next time and the next person that has a similar problem...
Thank's to everybody for the help!
adamzelazowski
02-24-2009 01:40 PM
