duraspark ignition erratic???
Originally Posted by ErrorS
Are you 100% sure your mechanical advance is OK?
Exchanged the Duraspark box with a known good one from a different truck I scapped a while back... and it is still acting up. I'll check the ignition coil and disassemble/inspect the distributor tomorrow. Anyone know the resistance specs for the ignition coil windings? I thought they were listed on the old Sun Tune-up cards...
Any other suggestions???
[QUOTE=Mil1ion
How many miles on this engine ?
Hi-Miler ?[/QUOTE]
A few thousand since the rebuild, maybe about 6000 or so. Distributor may have as much as 140,000 on it though. Tomorrow it has an appointment on the operating table (workbench).
When watching the timing marks under the timing light, they are nice and steady (not jumping or bouncing around) when the engine is idling and revved.
BTW, Thank you very much for the resistance specs. Exactly what I needed!
Hi-Miler ?[/QUOTE]
dyingtolive
297
05-24-2021 09:15 PM
Galendor
20
05-25-2016 01:44 PM
Rubenk
54
10-09-2010 07:41 PM
79F-1504x4
05-28-2010 09:39 PM
12a199a1b, advance, bad, coil, d7ae, d7az12a199a, distributor, duraspark, ford, ignition, irratic, problem, retard, specifications, symptoms
