It has to be an electrical problem, if he's gone this far and it hasnt started. When i replaced my HPOP with a Terminator, it took only 10 seconds (if that) to start up.
i got the ressie filled and keep filling it as it takes it. should i stop woorying about the oil level? i've been crankin for a while now, every 5 mins. for about 30 sec. i'll keep doing it. triple checked sensors, etc
maybe if this doesnt work soon, i'm going to hunt down a pressure gauge and connect it to the hpop. does it matter which side? i'm wondering if the hpop shaft is spinning
none of the sensors are mistakable. i've vhecked them a bunch of times. i dont have a clue whats wrong. i wish i had a chevy 350 in my excursion (with a freakin carb)
no smoke out of exhaust while cranking. the question is fuel or spark. would there be any codes to check for. could my diablo predator programmer tell me any codes?
Tach not moving is sometimes a pointer for the cps. If you have an extra it would be a good time to change it and see. If not, get one for a spare, change it, if it works good, if not, the you still have a spare. Make sure you use OEM and stay away from after market. Too many problems from the aftermarket.
