410 pistons
Old 07-08-2001 | 09:45 PM
57fordfreak's Avatar
57fordfreak
410 pistons
I am currently building a 410, but I am having trouble locating a set of standard bore pistons. Any help would be much appreciated.
Old 07-08-2001 | 10:30 PM
FE427TP's Avatar
FE427TP
410 pistons
Summit has cast Sterling 381P pistons for the 410 but they are backordered at $10.69 a hole you could also try ford power parts, and I've heard NAPA even carries a piston for the 410, if nothing else order the low compression 390 piston on the condition that you'll take it if it measures to the right height
Old 07-10-2001 | 09:18 PM
DrFord's Avatar
DrFord
410 pistons
Old 07-11-2001 | 09:14 PM
JMC67's Avatar
JMC67
410 pistons
try www.kanter.com they show them. I'm sure they are cast because if I remember right they were quite inexpensive . I built a 410 and found this site after I spent $400.00 on a set of pistons.
OrangeJuice
04-08-2010 02:02 PM
Kennewick
11-15-2009 09:57 PM
crescentwrencher
13
05-28-2008 10:23 AM
yomow
02-16-2004 04:41 PM
Jamey L. Hanis
10-22-2003 04:36 AM
Quick Reply: 410 pistons
