Rochester 2GC carburetor on 1935 Flathead?
Old 10-10-2007 | 03:02 AM
ccbb's Avatar
ccbb
I wanted a auto choke carburetor for a custom car I'm building.
I picked up a Rochester 2GC carburetor, with automatic choke.
and the Speedway three bolt to four bolt adapter
http://www.speedwaymotors.com/p/808,...r-Adapter.html
I read they used the Rochester 2GC on 1953 Mercury Flatheads and Speedway recommended it for the adapter I bought on their Web site.
Hopefully this will work on a stock 1935 Ford flathead engine. It has the Mallory electronic distributor on it also. Thought I would post this for any comments before I blow the engine up for trying, or possible problems... anyone else use other type carbs?
Old 10-12-2007 | 10:48 AM
mtflat's Avatar
mtflat
I don't know why your plan wouldn't work but I haven't messed with the early engines very much. For the mother-lode of flathead information and another bunch of great guys try this:
http://groups.msn.com/FordFlathead19...3/general.msnw
Especially browse thru the links on the left side margin and pay special attention to rumbleseat's tips and the techno page.
Old 10-23-2007 | 11:31 PM
The Frenchtown Flyer's Avatar
I use a 2GC on my '30 Tub with a 302 and it works great. I turned it around so the bowl faces the backward - that way there is room for two additional "dummy" carbs for a faux tri-power without them hitting the front mounted distributor. Good luck.
Old 10-24-2007 | 04:17 AM
ccbb's Avatar
ccbb
Sounds good, I picked up a 2CG but see the base is too large to fit the flathead adapter...I guess there must be a small model. Any idea if those where called something different or different application I should look for?
white 66
21
06-29-2017 04:30 AM
white 66
1947 and Older Ford Trucks
02-21-2017 09:53 PM
mstng5point0
10-20-2012 03:38 PM
merten
17
10-18-2007 11:02 PM
BigBlue88
25
05-26-2007 04:23 PM
Quick Reply: Rochester 2GC carburetor on 1935 Flathead?
