D66 in!
D66 in!
So, started at 9am this morning and was done by 4pm, including lunch time. Removal wasnt terrible, ended up not removing the pedistal because of the lack of access to the rear driverside bolt on the pedistal. reached under the pedistal and unbolted the turbo from it and she came right out! install went well. the only problem i ran into was a minor oil leak on my ebpv actuator rod. i'll address that later. i took plenty of pictures and will be working on a writeup this week. thusfar, loving the performance. sounds about the same, but clears a good bit of the smoke rather quickly. thanks to all who gave advice and good wishes. ill keep yas posted, and keep an eye out for my writeup.
-Brandon
-Brandon
no vids yet, but working on the write up with pics on the install after i get done studying for one of my nursing exams tonight (god help me!). didnt' really push the boost business much yet due to the fact that my clutch is in need of an upgradeand anything over 2500rpm on moderate and up acceleration results in some serious slippage. once i get the courage up to test her out good, ill let yas know.
FFemt5287 I bet you anything the actuator leak is caused from you un screwing the rod connector. There needs to be about 1/4 of pull on the rod before you connect it to the ball of the ebpv. It happened to me
-Brandon
Originally Posted by powerstroked162
With stage 1's you'll see about 28psi with a good tuner. Glad to hear all went well for ya! I cant speak well for the owner of the company but his products are top notch enjoy!
Cowboy Steve
Cowboy Steve
and I can speak well of the company owner, he is a stand up guy, and
great to deal with...
to the OP, you'll love the turbo, mine has held up well so far even with 3's
Originally Posted by rtxcoon
try 36-38psi with a great custom tune guy...
And I used to speak well for the guy til he leaked out personal information to others without my permission. Thats outta my hands now tho, gotta love the B.B.
Cowboy Steve
On stage 1's, its not possible. Even Bean told me that himself, so argue with him about it but Im just goin off what the guy who had the turbo designed said buddy
Cowboy Steve
Cowboy Steve
that 38psi was on stock turbo, stage 1's, and tw tuning, no intercooler
I didnt put the d66 on until after I got the stage 3's installed...my bad
buddy
you know what, your right....I got my parts install out of order,,,
buddy
buddy
Cowboy Steve
Glad you Like the D66 Brandon!
Steve, you asked me to find your records ON THE FORUMS so let it go buddy. You must be sore because you have been telling everyone that you have S2's and my records show you bought S1's?
I have the reciepts that show otherwise. Your right, iasked for my records, not for you to give out my name, address, and phone number to those seking it. Come on Bean you have to be wiser then that. I tell ya what really ticks me off is that I have went outta my way to send customers your way and you could give two chits less as to keepin my personal info personal. I now have to scrape off the numerous BDP banners i have plastered on my truck that YOUR COMPANY sent me to have put on my truck to show my support.
The Real Cowboy Steve
