1965 wiring diagram
#31
#33
I do have the cats meow for 65 truck wiring diagrams...name your series...Ive got em all..from E series all the way to T series...email me with your needs...the book you always see everywhere I have and its sorta kinda close to the actual trucks wiring...but Ive got parts harnesses Ive compared the pamphlet to as well as my book...a FoMoCo published book btw...the Ford book its dead nuts on correct...
- cs65
- cs65
Ropeta-65-CS
#34
I have a 66 f100 custom that the PO had the work done on it & there were to many hands in the fire. I think he took it in as he had the funds, so the wiring is not done right. It drains the battery after around 4 or 5 days. While looking on the net I found this site were someone put up a diag. if you print it as 4 tiles you can paste it back together in 1 big one.
My problem is that they put in a MSD 6al ign, which is not bad but there is a wire in the wrong place. They filed out the hole were the switch goes & put in a after market switch, so now my new switch will not fit. It has a push button over the switch, so you turn on the switch then push the button to start it. So they have the wires all messed up, I think it is wired like the key is on all of the time. I just now printed this one off so I am going to try & find out what they have done. Here is the site.
http://www.justanswer.com/uploads/se...ng_diagram.pdf
Hope this helps it looks like I can at least find out what they have done using this diag. Then I have to try & weld some spot welds & file them so the switch will fit. Any one have a different way I can fix the hole so the switch will ift.
Bill
Bill
#35
- cs65
- cs65
#36
1965 F250 charging system
- cs65
- cs65
#37
Do you have a Alternator? or a Generator? AN Alternator is a Generator that has an INTERNAL Voltage regulator and does not need a Voltage regulator.... A Generator has no Voltage regulator built in, and consequently needs an external regulator. If you have an Alternator and are also using a Voltage Regulator that would explain your issue, as you are regulating the Voltage twice......
#38
Alternator/Regulator
#39
Ive got a 65 Mustang in the garage. Other than the length of the wires, all the connectors and the harnesses themselves seem to be made up the same as my 66 F100 for the most part. There are some differences but not many.
The Mustang parts vendors sell most of the harnesses, so that could be an option for people who want to retain an oem looking harness.
#40
My truck is a '66 F100, but I would bet the electrical system is similar to yours. My factory shop manual is for a '66, so some of the numbers may not match yours exactly, but you should be able to find the same things. Group 13 - Charging System, page 13-2, Figure 1 shows the wiring diagram for the Autolite Alternator System - Indicator Light. Page 13-4 shows the trouble shooting logic tree for "Charge Indicator Light Stays On. Note 3 says check the operation of the voltage regulator. Even though you have a new one, it may be defective or there may be a wiring error. You're getting good output from the new alternator? Does it still measure good coming out of the regulator? Neither my '66 Wiring Diagram nor my '66 Owner's Manual electrical section say anything about there being an in-line fuse. Hope this is of some use to you.
#41
#42
PS. it just dawned on me, I have an extra 65 cab if you need anything off of it. I just bought a 66 to replace mine on the 65 so I'll have a complete cab and chassis left over when I'm done.
#43
the difference between an alternator and a generator is the generator produces DC voltage, the alternator produces AC voltage which is then run threw diods to convert it to DC.
#44
diagrams
if anyone is interested I just went looking around and I have a selection of diagrams as well as component locations for at minimum 1965 and 66.
if someone has a place I can post them all, I will, if not give me your email address and i'll send them out, I have quite a few from different sourses, maybe 20 in jpg form.
#45
65 F-250
Great, just wondering if you would mind emailing me electrical diagrams to cover 1965 , 1966 perticulary for the charging system and all under the hood. I would be very grateful if you would. Thanks
By the way, looks like you have a 66 f-250? Question- do you know if there is an inline fuse involved with the charging system anywhere in the circuitry. I have new alternator, new voltage regulator, starter selonoid, grounding cable battery to block and have cleaned any contact points for grounding of charging system that I can find and still the alternator stays on all the time. I know that that can happen if there is a problem with the voltage regulator plug contact pins but the thing is that anytime I disconnect the neg. cable from battery, the engine dies. The alternator is new and putting out charging current to meet specs so shouldn't the truck engine continue running even with the battery disconnected??? This is why I am thinking that there is a inline fuse that has gone bad or there is still a grounding problem somewhere?? May with help of the elec. diagram I can find location of a inline fuse if there even is one at all. any help on this since you have f-250? my email address is : rayejohnson@q.com- and thanks a lot for help thus far.
