2003 F250 v10 ABS light problems
So all of a sudden the ABS light comes on when I am driving and the speed odemeter drops to 0mph real quick and then the ABS light goes off and the odemeter goes back to normal speed. It seems to happen if I am going any speed. Just got back from a road trip and It has been doing this every 15 mins or so off and on. I may be a simple fix but before I just drove it down to the dealership I thought I would ask the pros first!
The following users liked this post:
While driving have you noticed when the ABS and Speedo do their thing the truck will slightly hesitate or hiccup?
The "with a load" makes sense, if the sensor is experience a heat-related failure.
Many sensors get like that - they break internally, and when heated, the connection breaks. Cool off, it's fine.
The rear end gets warm/hot when you're towing/loaded, that's for sure
So, yeah, definitely sounds like a heat-related thing. Change it anyway ...
I haven't noticed it hesitate, all I noticed is the speedo and abs light going crazy. It hasn't done it in awhile and I haven't messed with the VSS or anything yet. Maybe only with a load it does it?
As a trouble shooting step I have pulled the ABS fuse, ABS light is on all the time, however the speedo no longer drops out.
The hesitation might have been a partial operator error.
Changed the fuel filter and air filter, much smoother now. (fuel filter - 78.5k miles, air filter - 40+k miles)
I looked at the VSS thing but did not dig into it at the time, I was to upset that I needed a tool to take the fuel filter off.
My F250 V10 is doing this exact thing, random brake light with a simultaneous engine stutter and mph/rpm gage going to zero, did anyone figure this mystery out?
Jasonpremo
07-21-2013 01:53 PM
croweagle
1997 - 2003 F150
29
02-05-2008 02:06 PM
