Engine coolant blowing out of coolant reservoir 6.0L power stroke
Old 05-07-2007 | 12:37 PM
edabb's Avatar
edabb
Exclamation Engine coolant blowing out of coolant reservoir 6.0L power stroke
i have coolant blowing out of my coolant reservoir when ever i hold it to the floor it does it with or without the banks programmer, any ideas
Old 05-07-2007 | 12:52 PM
fatheadon1's Avatar
fatheadon1
my 05 with the banks is doing the same thing it was 1 gal low when i checked it i filled it up and cleaned my motor and its all gone and my motor is a mess
Old 05-07-2007 | 12:55 PM
diesel_dan's Avatar
diesel_dan
Head Gasket
Old 05-07-2007 | 12:56 PM
edabb's Avatar
edabb
i took it to the shop and they said it was the egr cooler they changed it and that didnt fix it so now they are going to try putting new head gaskets on it
Old 05-07-2007 | 12:57 PM
Enomra's Avatar
Enomra
Good luck getting them to pay for it. We are all hoping that it gets resolved for you.
Old 05-07-2007 | 02:17 PM
LI PerformanceDiesel's Avatar
make sure they check the head before re installing them and go back with stud and / or wire ring gaskets
Old 05-07-2007 | 05:52 PM
WishIhada7.3's Avatar
WishIhada7.3
ya second on the studs spend the 500 and have the dealer put them in.
Old 05-07-2007 | 06:35 PM
edabb's Avatar
edabb
I tried to do that but they said that they couldnt put them on even if i brought them to them
Old 05-07-2007 | 07:15 PM
FoMoCo136's Avatar
FoMoCo136
Mine made a small bit of white spots once. Should I consider retorqueing them? I have not seen it anymore but there was some white spots around the fill cap on the resovior.
Old 05-07-2007 | 07:36 PM
WishIhada7.3
tell them your gonna take it to a different dealer then....no need to keep puting junk back in specially if u plan to play......
Old 05-08-2007 | 07:29 AM
2003 Stroke's Avatar
2003 Stroke
good luck w/ this issue....ur not gonna get a lot of help most likely...it is not the head gaskets...i have had mine checked 5 different times for the same issue and they always hold pressure...it is not the egr cooler....it is likely to me the plastic cap heated up, warped, and is now letting the coolant by...just leave the coolant at the min level or little below and it won't spew out the cap....best advice i can give...i've beat my head against the wall w/ this one w/ my dealer...imo only...good luck!
Old 05-08-2007 | 03:53 PM
tiredlr's Avatar
tiredlr
I am one of many that have had the same issue. Dealer couldnt get truck to puke coolant, as it did it mainly when towing. They decided to replace the EGR cooler, and the problem still existed.
So i bit the bullet and had the ARP head studs and the Hypermax wire ring gaskets installed that LIPD recommended. Problem solved. One of the best upgrades you can do if you run a programmer or module IMO.
Old 05-09-2007 | 07:10 AM
2003 Stroke
tiredlr...was your truck puking coolant out of the overflow??
Old 05-09-2007 | 09:29 AM
Enomra's Avatar
Enomra
Most likely it was. I see you have an edge programmer and they are notorious for Over boosting. A good friend of mine had one and it would boost up to 55psi and caused him a lot of trouble on his 2003 6.0. But I tell you what that truck would really run......
Old 05-09-2007 | 01:40 PM
2003 Stroke
yea..it definitely does it more w/ the box on, but even w/out it, it will still spew...i've given up on it...but i do have the max boost warning or safety point set @ 30 lbs and my record boost does not go over 28...i'm sure it's a flaw in the software...not really please w/ it...but it does run!! not scared of anything hardly...
