I put a 2.5" leveling kit on my truck and 325/ 65/ 18's on it. There is a very slight rubbing (very very slight) on the driver side. It occurs at the rear of the wheel well. I am going to pull the plastic back or remove a portion of it and it will fix the issue simply. Truck has 2600 miles on it with no issues.
if the leveling kit isnt on the truck does the tires still rub?
Yes 35" tires fit without a leveling kit. While 325/65R18 will fit, they are a little to wide for a factory 8" wide rim. 35X12.50R18 is a better fit for both the rim and the truck. The 35X12.50 is just as tall as the 325 but a bit narrower.
BFG's are fine. Except I would go with either the 305/65R18 A/T or the 35X12.50R18 M/T. Alot of shops will not mount a 325/65R18 tire on factory rims due to safety/liability issues.
