Deer Ropin
Old 03-22-2007 | 10:09 AM
DaMole's Avatar
DaMole
Thumbs down Deer Ropin
I thought yall might like this I got it emailed to me.
Now I will have to make new plans for the weekend .
My name is Gary and I had this idea that I was going to rope a deer, put it in a stall, feed it up on corn for a couple of weeks, then kill it and eat it. The first step in this adventure was getting a deer. I figured that since they congregated at my cattle feeder and do not seem to have much fear of me when we are there (a bold one will sometimes come right up and sniff at the bags of feed while I am in the back of the truck not 4 feet away) that it should not be difficult to rope one, get up to it and toss a bag over its head (to calm it down) then hog tie it and transport it home.
I filled the cattle feeder then hid down at the end with my rope. The cattle, which had seen the roping thing before, stayed well back. They were not having any of it. After about 20 minutes my deer showed up, 3 of them. I picked out a likely looking one, stepped out from the end of the feeder, and threw my rope. The deer just stood there and stared at me. I wrapped the rope around my waist and twisted the end so I would have a good hold. The deer still just stood and stared at me, but you could tell it was mildly concerned about the whole rope situation. I took a step towards it. It took a step away. I put a little tension on the rope and received an education.
The first thing that I learned is that while a deer may just stand there looking at you funny while you rope it, they are spurred to action when you start pulling on that r ope. That deer EXPLODED.
The second thing I learned is that pound for pound, a deer is a LOT stronger than a cow or a colt. A cow or a colt in that weight range I could fight down with a rope with some dignity. A deer....no chance. That thing ran and bucked and twisted and pulled. There was no controlling it and certainly no getting close to it. As it jerked me off my feet and started dragging me across the ground, it occurred to me that having a deer on a rope was not nearly as good an idea as I originally imagined.
The only up side is that they do not have as much stamina as many animals. A brief 10 minutes later, it was tired and not nearly as quick to jerk me off my feet and drag me when I managed to get up. It took me a few minutes to realize this, since I was mostly blinded by the blood flowing out of the big gash in my head.
At that point I had lost my taste for corn fed venison. I just wanted to get that devil creature off the end of that rope. I figured if I just let it go with the rope hanging around its neck, it would likely die slow and painfully somewhere. At the time, there was no love at all between me and that deer. At that moment, I hated the thing and I would venture a guess that the feeling was mutual. Despite the gash in my head and the several large knots where I had cleverly arrested the deer’s momentum by bracing my head against various large rocks as it dragged me across the ground, I could still think clearly enough to recognize that there was a small chance that I shared some tiny amount of responsibility for the situation we were in, so I didn’t want the deer to have to suffer a slow death.
I managed to get it lined up to back in between my truck and the feeder, a little trap I had set beforehand. Kind of like a squeeze chute. I got it to back in there and started moving up so I could get my rope back.
Did you know that deer bite? They do! I never in a million years would have thought that a deer would bite somebody so I was very surprised when I reached up there to grab that rope and the deer grabbed hold of my wrist. Now, when a deer bites you, it is not like being bit by a horse where they just bite you and then let go. A deer bites you and shakes its head, almost like a pit bull. They bite HARD and it hurts. The proper thing to do when a deer bites you is probably to freeze and draw back slowly. I tried screaming and shaking instead. My method was ineffective. It seems like the deer was biting and shaking for several minutes, but it was likely only several seconds. I, being smarter than a deer (though you may be questioning that claim by now) tricked it.
While I kept it busy tear ing the hound out of my right arm, I reached up with my left hand and pulled that rope loose. That was when I got my final lesson in deer behavior for the day. Deer will strike at you with their front feet. They rear right up on their back feet and strike right about head and shoulder level, and their hooves are surprisingly sharp. I learned a long time ago that when an animal like a horse strikes at you with their hooves and you can’t get away easily, the best thing to do is try to make a loud noise and make
an aggressive move towards the animal. This will usually cause them to back down a bit so you can escape. This was not a horse. This was a deer, so obviously such trickery would not work.
In the course of a millisecond I devised a different strategy. I screamed like a woman and tried to turn and run. The reason I had always been told NOT to try to turn and run from a horse that paws at you is that the re is a good chance that it will hit you in the back of the head. Deer may not be so different from horses after all, besides being twice as strong and three times as evil, because the second I turned to run, it hit me right in the back of the head and knocked me down.
Now when a deer paws at you and knocks you down it doesn’t immediately leave. I suspect it does not recognize that the danger has passed. What they do instead is paw your back and jump up and down on you while you are laying there crying like a little girl and covering your head. I finally managed to crawl under the truck and the deer went away.
Now for the local legend. I was pretty beat up. My scalp was split open, I had several large goose eggs, my wrist was bleeding pretty good and felt broken (it turned out to be just badly bruised) and my back was bleeding in a few places, though my insulated canvas jacket had protected me from most of the worst of it.
I drove to the nearest place, which was the co-op. I got out of the truck, covered in blood and dust and looking like I’d just come from a bar-room brawl. The guy who ran the place saw me through the window and came running out yelling "what happened" I have never seen any law in the state of Kansas that would prohibit an individual from roping a deer. I suspect that this is an area that they have overlooked entirely. Knowing, as I do, the lengths to which law enforcement personnel will go to exercise their power, I was concerned that they may find a way to twist the existing laws to paint my actions as criminal. I swear, not wanting to admit that I had done something monumentally stupid played no part in my response. I told him "I was attacked by a deer." I did not mention that at the time I had a rope on it. The evidence was all over my body. Deer prints on the back of my jacket where it had stomped all over me and a large deer print on my face where it had struck me there. I asked him to call somebody to come get me. I didn’t think I could make it home on my own. He did.
Later that afternoon, a game warden showed up at my house and wanted to know about the deer attack. Surprisingly, deer attacks are a rare thing and wildlife and parks was interested in the event. I tried to describe the attack as completely and accurately as I could. I was filling the grain hopper and this deer came out of nowhere and just started kicking the hell out of me and BIT me . It was obviously rabid or insane or something. EVERYBODY for miles around knows about the deer attack (the guy at the co-op has a big mouth).
For several weeks people dragged their kids in the house when they saw deer around and the local ranchers carried rifles when they filled their feeders. I have told several people the story, but NEVER anybody around here. I have to see these people every day and as an outsider, a "city folk", I have enough trouble fitting in without them snickering behind my back and whispering "there is the dumb-*** that tried to rope the deer. I just thought I should perhaps pass this along in case any one else thought this was an intelligent thing to do...
Old 03-22-2007 | 10:55 AM
bigdaddyII's Avatar
bigdaddyII
Thats great! Those bright ideas that I get from time to time usually end up like that.
Old 03-22-2007 | 11:00 AM
rednekrailroader's Avatar
rednekrailroader
HAHAHAHA that's the funniest thing I ever heard!
Old 03-22-2007 | 11:12 AM
nubeee1's Avatar
nubeee1
Short bus material!!!!!!
Old 03-22-2007 | 11:22 AM
NH-Hottie's Avatar
NH-Hottie
Man 0 , Deer 1
Do you think he got the rope off? If not, I think he should try again. Maybe this time the deer will finish him off.
Old 03-22-2007 | 02:57 PM
Kwikkordead's Avatar
Kwikkordead
The email will continue.
Old 03-22-2007 | 09:02 PM
DaMole's Avatar
DaMole
Keep it going around it will cheer up almost anyones day.
Old 03-22-2007 | 09:06 PM
71dusterdan's Avatar
71dusterdan
shoulda stuck with goat ropin. that was priceless. Dan
Old 03-22-2007 | 09:18 PM
Indy_Gearhead71's Avatar
Indy_Gearhead71
OMFG, that's about the funniest thing I've ever read, my eyes are still watering from it.
Definitely you might be a redneck material.
Old 03-22-2007 | 10:13 PM
rangerfan's Avatar
rangerfan
That was the best story I read in a long time. The writer actually put you at the scene.
Old 03-22-2007 | 11:21 PM
smokestone52's Avatar
smokestone52
My old man had a penchant for telling stories. Especially when he was wrestling with 'ole Jim Beam. This story cracks me up everytime I think of it. So obxredneck, you brought this story to mind, and by the way yours was a classic.
My Dad said after a day of freezing rain, snow and sleet, hunting deer in central Idaho, he and his youngest brother called it a day and went back to the truck and headed home. Suddenly two does ran in front of the truck, Dad hit the brakes just as a four point buck jumped in the back of the truck. (that would be an 8 point, for you all east of the big river, and folks from Rio Linda Ca.)
Well, the 'ole man hit the brakes again, and my Uncle jumped out, and being a onry ole cowboy, began to steer wrestle with this big buck. As the story went my uncle was gored three times, stomped on, bitten and pooped on. My Dad had his rifle trained on the ball of fur and human flesh but could not shoot since his brother was in the sites as often as the deer. Finally the deer jumped free, and my dad shot it in full flight out of the truck.
Now, I always called BS when my dad told this story. Well, my dad has been gone since 1998. Last winter I got to visit with my uncle. He is looking pretty old, but his mind is as spry as a spring chicken. I will be danged if during our weekend together, if he didn't ask me, "hey did your dad ever tell about the time I wrestled a deer in the back of your dads pick-em-up truck?"
I dang near fell over. Now I don't know what to believe!
Old 03-23-2007 | 06:56 AM
IB Tim's Avatar
IB Tim
Site Administrator
The guy should try cow tipping...
Old 03-23-2007 | 08:00 AM
tjc transport's Avatar
tjc transport
i ain't rite
ya know Tim, your post made me think of something even better than cow tipping, and made me laugh. tractor tipping.
to figure out what i am talking about, get a copy of the movie cars.
Old 03-23-2007 | 08:59 AM
68murc's Avatar
68murc
O.K. here's another one. My dad told it to me, and it was verified by my uncle, who was the victim. They were hunting, and my uncle shot at a buck (not sure what size) and dropped it in it's tracks. Him and dad walked up to it, and my uncle wanting to show off his prize, stepped over it, straddling it, grabbed it by the rack and hoisted the buck's head so my dad could take a picture...can you guess what happened next? Yup... the buck jumped up with my uncle on it's back, and he rode it around hangin on to it's rack, with the deer tryin' to 'buck' him off, him yellin' at my dad to shoot it. Eventually he fell off, and my dad knocked it down again for good. After they've had a few beers during huntin' season, they always tell the story better than this. Dad says his brother was not the macho-ist of guys while riding the dear. From then on, every time dad, and me also, have walked up on a deer we've shot, we always walk up from behind, and put another shot into the back of the head...just to be sure.
Let's keep this one going! Everyone has a good huntin' season story.
Old 03-23-2007 | 09:20 AM
bigskymt's Avatar
bigskymt
Mine isn't as good as some of yours.. but here it goes.
My dad, brother, brother in law and myself were deer hunting in Central Arizona. We just finished the morning hunt and were eating breakfast. All of a sudden shots ring out from over the hill.. we look up and here comes this decent 4 point running over the hill heading right for our camp. As you could imagine, there is a mad scramble for the guns and plates of bacon and eggs are flying about. Anyway, my brother in law shoots the deer maybe 75 yards from camp. We are gathered around the deer and look up on the hill only to see a couple of dejected, poor shooting hunters.
We end up going to the local bar to to have a few cold ones.. we are playing pool and a couple of hunters walk by.. and I hear one of them mumble "we should buy their damn beer for them too"
Last edited by TigerDan; 03-23-2007 at 09:36 AM. Reason: Language- Changed "f**king" to "damn"
