I just read over this thread and I think the problem I am having with my 2001 Ford Ranger may be this "valve body" problem but I wanted to make sure. I have a 2001 Ford Ranger 4x2 with the 4.0 SOHC engine. It has an automatic transmission. The transmission seems to lag in shifting from 1st gear to 2nd gear sometimes. In addition the overdrive light seems to flash randomly. The truck only has 65K miles on it. Does anybody have any ideas what may be causing this? What are the symptoms of the valve body problem? Are there any other parts that may cause these problems?
just accelerate gently with it in first then when it gets reved up a little bit let off
Matt
I put it in 1st, and it idled down a slight bit, and started movie forward. I pressed the accelerator a bit and then let go and it kept going, eventually slowing down because I had begun to go up a hill.
u should feel it pull the trucks speed down. this is a very good indicator that your valve body is leaking by due to a gasket problem. please list all vehicle info you have
you are a prime contestant for the valve body issue. the only thing i can suggest is pulling the valve body and taking a peak. have you read the article on how to fix this?
Matt
Yes I read the article. $100 at the dealership vs. $4000 to replace the transmission, is okay by me. Is there some other ways I can tell for sure if I'm having this problem, without pulling the valve body? Do you think I could still drive the truck for a little while longer while I save and get some other dead cars out of my garage so I can do this?
i wouldnt recommend driving the truck very long at all. the more it messes up the more bands you are eating and the shorter the life of the trans. your looking at it like i did, even if it doesnt fix it, its worth the risk because of the possible savings.
From the parts list I wouldn't think they rebuilt your trans, looks like they rebuilt THE problem clutch pack and replaced a band. Not enough parts for a rebuild.
