99 Explorer - Flashing O/D Off Light
Old 02-23-2007 | 05:16 PM
fordboy_52's Avatar
fordboy_52
sent...
Matt
Old 02-25-2007 | 01:41 PM
nikkiree's Avatar
nikkiree
wm_sorg,
I'll send it to you...
nikkiree
Old 02-25-2007 | 01:42 PM
nikkiree's Avatar
nikkiree
oops...already sent!
Old 02-25-2007 | 11:32 PM
Ponyracer's Avatar
Ponyracer
Matt have you sent this to the FTE staff to put in into a sticky on the top of this forum? This is such a big known problem with the A4LD/4R44E/4R55E/5R44E/5R55E in the Ranger/Explorer/Aerostar. I should know I did loads of them as a Ford Trans Tech.
Old 02-26-2007 | 02:37 AM
fordboy_52's Avatar
fordboy_52
yes, its being re-created since i cant write to save my life. but ken and i and tim are working on it
Matt
Old 02-26-2007 | 06:57 PM
nikkiree's Avatar
nikkiree
Problems With Obtaining A Separator Plate
I went to the dealer to pick up the filter and separator plate...the filter kit was no problem...on the other hand, the separator plate was the issue. I could get a separator plate, but I had to buy an entire assembly that included the valve body, solenoids, etc... that costs approximately $700+. Basically, you can now NOT buy the separator plate w/gasket as a separate component.
Therefore, I'm looking for some direction/help again:
- Should I still replace the filter?
- Should I try to fill in the broken gasket area with some sealant?
- Should I try to fill in the broken gasket area with a mocked up gasket?
All comments are welcomed!!! ASAP!!
Late,
nikkiree1
Old 02-26-2007 | 06:59 PM
fordboy_52's Avatar
fordboy_52
once again your dealer is lying to you. i purchased the plate with bonded gaskets and it was aprox $15 ?
what year is your truck?
Matt
Old 02-26-2007 | 07:24 PM
nikkiree's Avatar
nikkiree
Darn dealers...
My truck is a 1999 with the 5r55e trans...
I kind of belive the guy because he turned the computer around and showed me that he could not order it separately...
Now, I did call earlier in the day and it seemed that I could order the part separately (at least that's what the day guy said)...sounds a little fishy!
Does anyone have a part number?
I'm going to try to go there during the day to get the day time parts department instead of the afterhours like I did tonight (sidenote: their parts department is open 24 hours from Mon-Fri...pretty sweet I think)
Unless, someone could hook me up with the part? I have no problem paying!
Lastly, I did call another Ford dealer and they said that they could not order the separator plate as wel...
Thanks in advance,
Nick
Old 02-26-2007 | 07:32 PM
fordboy_52's Avatar
fordboy_52
dont buy a valve body, they are just trying to sell you parts. i can look the parts up tommorow at work because i have the ford cd's there
Matt
Old 02-26-2007 | 07:40 PM
nikkiree's Avatar
nikkiree
Matt,
I at least know not to buy the valve body!!!
Again, thanks for the help...I'll be waiting for your response tomorrow.
Late,
Nick
Old 02-26-2007 | 08:13 PM
nikkiree's Avatar
nikkiree
Is this the part number? Check out this Ebay auction...
F6TZ-7C155-A
http://cgi.ebay.com/ebaymotors/NEW-FORD-VALVE-BODY-GASKETS-AND-SEPERATOR-PLATES_W0QQitemZ270090917310QQcmdZViewItem
Or is it one of these...
A new separator plate (7A008 or 7Z490), upper/lower separator plate gaskets (7C155 and 7D100 used only with a 7A008 plate)
Thanks,
Nick
Old 02-26-2007 | 08:29 PM
fordboy_52's Avatar
fordboy_52
i heard user numberdummy is good to contact. you should look him up and see what he can tell you
Matt
  #28
Old 02-26-2007 | 09:59 PM
Method's Avatar
Method
fordboy_52,
Can you also send me your "valve body gasket tutorial"?
shanemenard@hotmail.com
Thanks
  #29
Old 02-26-2007 | 10:23 PM
fordboy_52's Avatar
fordboy_52
will do tommorow at work...
Matt
  #30
Old 02-26-2007 | 10:48 PM
Ponyracer's Avatar
Ponyracer
Matt
Yeah that dealership parts **** was on crack. you dont have to replace the valve body just the gaskets with the new updated molded separator plate for the newer models.
