73 Ranchero 500
Old 02-20-2001 | 10:47 AM
FTE Ken's Avatar
FTE Ken
73 Ranchero 500
Old 07-19-2001 | 12:25 PM
63unibody's Avatar
63unibody
73 Ranchero 500
My brother has a 73 Ranchero with a seized 351. He wants to put a 429 in will it fit? and He wants to put on a hood from an older GT with hood scoop.
Nathan
Old 07-20-2001 | 12:57 PM
bbtkd's Avatar
bbtkd
73 Ranchero 500
A 429 will fit but you will need a few things. You will need different motor mounts, different transmission or bell housing (and possibly different transmission mounts), different accessory brackets (AC, PS, alternator), probably a 3 or 4 core radiator, probably different hoses, and expect some changes in wiring and vacuum hose locations. I have not done it (yet) but I have also been looking into it. If the 351 has a C6 behind it, that will make it easier since you will already have the right connections, driveshaft, mounts, etc otherwise you will need those too. You will want a C6 (if you want auto - not even sure the FMX was available for the 429/460). Lastly - put a 460 in it. They are easier to find, cheaper, more powerful, and they are the same block - so the same external size.
Not sure on the hood - a 1972 hood MAY fit, but any earlier will not.
Nathan
Tom
Old 07-20-2001 | 12:58 PM
bbtkd's Avatar
bbtkd
73 Ranchero 500
Oh yeah - one more thing - you MAY need stiffer front springs since the 429/460 engines are a bit heavier.
Tom
Old 08-20-2016 | 12:09 PM
the1kane's Avatar
the1kane
I noticed no one has been on this thread for 15 years...
Old 08-20-2016 | 12:14 PM
the1kane's Avatar
the1kane
Hello , I have a 79 ranchero with a 351 Windsor 5.8L engine. Do you know the vacuum hose diameters and lengths? I need to re-hose the Beast and I want to do it proper.
