I called the local international dealer here in alabama and gave then the part # 1847170c93 and the guy said this was just one fuel filter, I was under the impression you got them in pairs. Anybody got any info on this?
If you referenced that you had a 6.0L then he looked up the wrong filter kit. Int'l uses a single filter set-up on their version of the 6.0L... known as the VT365. The filter we need is used on another motor for them.
You want fuel filter # 1847170C92 (2 filter kit and O-rings)
If it did change they should still be able to look up the right ones at IH. As Beach said the International version is the VT365 but the filters our 6.0's use are the same as the VT275. Tell them that and they should be able to get you the right filters.
Go to my gallery... scroll down and I have made a scan of the Int'l box top of the fuel filters I have on hand. Click on the image/gallery and I have a photo of the 2-filter kit that you need.
