Vloney-- dealer says (tech) its the low oil pressure pump. its covered under the warranty. 100 dollar deductable for the work. i should get it back in 3-7 days.
The low pressure oil pump will not fix your problem. It is a leak somewhere in the high pressure oil system. Most likely the o-ring in the back of the high pressure pump or one of the o-rings on the top of one of the injectors. You may want to take it to another dealership and have them take a look.
thanks for the info! Called the dealer and they said that they have already ordered a part for the high pressure pump. hope it fixes the problem with the starting if they hit both the low and the high pressure side.
