Vacuum advance not working properly?
My engine builder pointed out to me that when u pull the dist vac tube off the carb, the idle drops noticably. He said it should not do that and that carb distrib vacuum port is not functioning right.
The result apparently is that I have full advance at idle.
Recommendation: a non vacuum distributor.
Does all this sound correct?
No, don't do that as it will trash your gas mileage. What brand of carb, on what engine and is the motor hot rodded? The carb is either adjusted wrong, as the throttle plates are to far open at idle letting the port opening see manifold vacuum at idle. Try readjusting the the carb per the manual. It is amazing how screwed carbs get when adjusted by self proclaimed experts. If you have a hot rodded motor, you make have to drill some holes in the throttle plates so you can close them properly at idle. The other possibility is the wrong port on the carb is being used (very easy to do on the Edelbrock carbs).
He maybe an engine builder but it doesn't mean he did the tuning adjustments right. You need to recheck them yourself. It's not rocket science and the Holley web site has all the instruction to do it. I have reset carbs that were done wrong by any number of different high dollar engine builders when their engines wouldn't idle properly, suddenly run fine after a twik job. Go here and find your carb # and follow the instructions.
http://www.holley.com/TechService/Instructions.asp
Vac/mechanical advance
Are you aware that there is a mechanical advance under the point plate? The OEM distributor has spring tangs that regulate the advance curve. The tangs under the plate are bent with a screwdriver to limit mechanical advance by spring tension and must be "dialed" in to establish the curve. When the idle falls is the vacuum hose plugged? Or wide open? A vacuum leak will lean the motor and raise the idle speed abit. If the hose is plugged, then it sounds like the diaphram has a leak. If the hose is open, the idle should rise, not fall. Is everything inside the distributor in order? Nothing sticking. Where is the timing, with and without the advance connected? And at what RPM is full advance and how much?.......aMP
aMoneypit, His primary problem is full vacuum advance at idle which means a carb problem first. If you are running manifold vacuum and this is what is happening with the carb throttle plates to far open at idle, this is the what you get and there is no way the mechanic advance has anything to do with this problem.
Initial setting
Originally Posted by MattP51
I will double check everythong tomorrow..please stand by
