Vacuum advance not working properly?
Old 09-11-2006 | 03:00 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
Vacuum Advance
Originally Posted by Bear 45/70
Vaccum advance was never designed to run off manifold vacuum and it is a poor way to cure your mal-adjusted carburator caused poor idle. Anyone that recommeds this is an unknowledgable engine person. Vacuum advance is a gas mileage increacing system. Running manifold vacuum to cure way to much cam in your motor (AKA poor planning) will work but with that much cam the vacuum levels will be lower than in a normal engine and there will be no mileage increase. Otherwise the cam belongs on a race track not on the street.
I don't think I made myself clear. I am suggesting to try manifold vacuum first, then if it does not run good, switch over to ported vacuum.
I'm not arguing-just stating the sequenc on should take.
The gentelman we are trying to help may very well be better off running ported vacuum.
I feel like we've both made good points for him to try.
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
  #32
Old 09-11-2006 | 04:58 PM
Alvin in AZ's Avatar
Alvin in AZ
Originally Posted by aMoneypit
I guess you're right, I don't. ...........aMP
That's right, MP, you don't!
It's all a guess from where -we- are sitting. :/
MP, are you new to website-forums and/or newsgroups by any chance?
If so (sounds like it to me) you can see this is a whole different world than the "real" one, huh?
It's as if each and every one of us is getting our words and wording scrutinized like GWB himself.
With your experience you have a lot to offer, the trick is to -add to- the common knowledge here (we'll all learn something and you too) and remember, on website forums only the moderator gets to have the final word on anything.
Newsgroups that way, are even worse... no one gets the final word there.
Being a libertarian I kinda like it that way, but I'm really weird. :/
Alvin in AZ
  #33
Old 09-11-2006 | 05:38 PM
Alvin in AZ
This thread's tally is 31 posts and 319 veiws.
"it's all about the thread"
If a guy posts something that's 100% "wrong". and it prompts a lurker or anyone to explain why in detail. The thread is a success. Neither post is more worthwhile than the other.
I never had numbers to back it up before but I always figured only about 10% were actually participating in any particular thread. (I'm new to website forums)
It's not the post or poster that's the most important IMO it's the tread and its combined information and rebutted mis-information that counts. With a 90% lurker count even the OP's (original poster) question can become secondary in a really good thread. Heck he may have asked the wrong question even. And he finds that out in a good thread.
After getting a Comp-Economy Cam in my 360/2100/DuraSpark, I had a little trouble with the engine advancing its own timing and so speeding up its own idle speed. I didn't drill holes in the throttle plate but I'm figuring on trying something like that some day.
The distributor port vacuum can get effected and away it goes.
It's a symtom of another problem, it seems to me, of the carb idling using at least some of the low-speed-circuit instead of solely the idle circuit, for idling.
Alvin in AZ
ps- There I made statments. You think I'm wrong or only half right, state your case for it, I'll agree with you or re-build my case, by the end of the thread we'll all be smarter?
tinman52
02-12-2015 08:21 PM
BaronVonAutomatc
03-25-2014 06:23 PM
Superred2
12-15-2010 12:43 PM
heavyd86
01-12-2008 01:54 PM
jeremyd72
08-30-2007 11:20 AM
