Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Passenger door locked & won't unlock
Old 12-06-2016 | 09:11 AM
Ben Absalom's Avatar
Ben Absalom
Originally Posted by FTE Trigger
hhnnmm...
How's he suppose to do that for a door that won't open?
you can take the rear door panels completely out with the doors closed the front are a little more tricky but you can take the door panel 90% off then you take the exterior door handle off that will disengage the actuator rode which is normally the problem any ways then you can simply open the door with the inside handle because its mechanical unlike the exterior which is activated by an actuator rode once the door is open you can find the problem and fix it
Old 12-06-2016 | 07:36 PM
scott91370's Avatar
scott91370
Two yêar old thread (10 year old question), betting it's fixed or sold by now.
Old 04-27-2017 | 07:16 PM
Rich3336's Avatar
Rich3336
My 04 Escape was stuck in the locked position
I saw the youtube video on how to fix this, and I was able to remove the door panel as in the video. A
little circular black plug hides the screw in the handle trim, removed that, took out the Phillips screw there, and inside the door pull. Pulled the panel off the door from the top down. Pulled it out enough to remove the water seal and paper that is between the panel and door.
worked the locks, and the metal lever that is next to the plug inside the door. Then, I noticed the outside handle was not pulling against anything inside the door. A few blasts of wd40 there, and manually operating the outside handle mechanism from the inside freed that up.
Then, one more cycling of the door locks, and it opened up from the outside. Total job start to finish was 20 minutes.
chief1600
1999 to 2016 Super Duty
12-05-2017 08:57 PM
sporta
1997-2006 Expedition & Navigator
10-16-2017 07:20 PM
Painey
07-25-2017 04:58 PM
haywoodya69
19
07-13-2017 12:13 PM
Sydneylh1
03-10-2016 09:08 PM
