hard start and blue smoke
Old 02-27-2006 | 12:30 AM
05f250fx4's Avatar
05f250fx4
anyone know whats goin on with my truck? 70 degrees today and my truck still started up as if it was 50 degrees. i also noticed a little blue puff of smoke. just one though. when i gave it a little gas, i got nothing. hard start to the point where my radio loses power, and a little puff of blue smoke.
Old 02-27-2006 | 12:40 AM
cangim's Avatar
cangim
HPOP maybe? Losing prime taking a while to build up to fire the injectors? Just a guess, I am sure others will chime in with thoughts as well.
Old 02-28-2006 | 01:34 AM
05f250fx4's Avatar
05f250fx4
shes only got 136k on her. so you think i would just need to replace the HPOP?
Old 02-28-2006 | 02:45 AM
cangim's Avatar
cangim
Just thinkin that it would be wise to check the level before you start it when it has been sitting a while to see if it is draining out. You really shouldn't need the GP to start at that temperature, but I would check to make sure that it is working correctly as well. I haven't had much experience with the HPOP as of yet, but do know if it is low on oil, it will take a while to build pressure to fire the injectors.
Old 03-01-2006 | 11:12 AM
05f250fx4's Avatar
05f250fx4
thanks for the tip
Old 03-05-2006 | 12:24 AM
05f250fx4's Avatar
05f250fx4
i checked the oil, it was low so i changed the oil and filled oil. now occasonally it will start hard. does anyone know whats going on?
jayron
1997 - 2003 F150
02-12-2014 05:22 PM
snell1228
Modular V10 (6.8l)
11-20-2011 10:14 AM
F250TruckR
10-31-2010 12:25 AM
Fordman400 4x4
10-07-2007 08:37 PM
Bandit0594
11-09-2004 07:03 AM
