F250 Airbag light blinks and stays on!
Old 03-02-2006 | 11:53 AM
Franklin2's Avatar
Franklin2
I think I would still check under the steering wheel and the column wiring. There is going to be something wrong with the wiring to the driver's side airbag. Check that clockspring too, maybe it has come undone somewhere and is touching metal. Or the harness in the column has a bare wire and is touching metal somewhere.
Old 10-13-2009 | 11:58 PM
lvmudscrew08's Avatar
lvmudscrew08
4wd Low
hey.. just had a alarm/ remote start install in my 08 250 and now it flashing a 19 code... what you think about that?
Old 02-26-2016 | 10:23 AM
Sean Kelly's Avatar
Sean Kelly
Airbag light
So I read the op. And also saw the codes. My lightflashes 2 then 7. So I assume code 27. There are two codes with a 27 tho. How can u decipher between the two. Thanks in advance
Old 02-26-2016 | 12:29 PM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE Sean.
air bag code 2-7 then solid light means the passenger side lockout light bulb is burned out.
good news is it is an easy fix, i think i paid $1.99 for two bulbs at radio shack.
took the lock switch out, popped it apart, changed the bulb and put it back together and back in in less than 45 minutes.
Old 02-26-2016 | 03:59 PM
Sean Kelly's Avatar
Sean Kelly
Do yu know which bulb it is I need to buy or could I pop the old one out and then being it in to radio shack and find the right one?
Old 02-26-2016 | 04:35 PM
tjc transport
i ain't rite
i used radio shack part #272-1141.
unsolder the burned out bulb, strip the insulation off the leads, pre tin the leads, then solder them in the board ans set the light wherever you want it.i leave the passenger airbag turned off, so i just have the bulb tucked in the switch assembly instead of in the hole so you can see it.
oops, looks like that bulb is out of stock at radio shack, they probably stopped selling them since they pretty much no longer sell electronics parts and switched to cell phones and gadgets.
any small 12 volt bulb will work though.
Old 02-26-2016 | 04:41 PM
Skip1970's Avatar
Skip1970
Damn what radio shack has become. Check out Frys electronics if there's one I. Your area
Old 02-26-2016 | 04:57 PM
Sean Kelly's Avatar
Sean Kelly
Thanks everyone!
Old 02-29-2016 | 02:05 AM
Sean Kelly's Avatar
Sean Kelly
Originally Posted by Sean Kelly
Thanks everyone!
Installed a new led. Airbag light cleared. Excellent. Thanks so much.
Old 02-29-2016 | 08:31 AM
tjc transport
i ain't rite
good deal. i have not tried led there yet, so did not know if it would work or not.
Old 02-29-2016 | 02:33 PM
Sean Kelly's Avatar
Sean Kelly
Yea fries didn't have a 12v lamp so I just grabbed a 12v led since I needed vehicle inspection this morning. Working fine for a couple days now
Old 12-13-2019 | 12:13 PM
Dennis Hudson's Avatar
Dennis Hudson
Air b
Thanks for this post. Replaced the passenger air bag light by soldering in a new bulb. It fixed the code 27 problem.
  #28
Old 03-05-2022 | 10:04 AM
xcorona's Avatar
xcorona
7th Gear
Try this procedure.
Hi. I am new here so not sure how to post yet but I have a similar problem to the reply here. Thank you in advance for your help.
I have a 2001 F250 Crew cab with 68,900 miles. My airbag dash code flashes 3 times and then six times then it stay solid. It has a new battery, airbag has not deployed, but I did find that the driver seat airbag sensor cable was pulled and no longer attached to my driver seatbelt. I replaced the seatbelt with airbag sensor attached from the Junk yard and it still flashes (did this with 2 seatbelts). Thank you for your help
  #29
Old 03-05-2022 | 10:55 AM
Dennis Hudson
Airbag light blinking
This happened to my 2001 f250 and it turned out to be the light bulb where you use the key to turn off the passenger airbag had burned out. I couldn't find an original bulb so I just soldered in a small bulb. Pretty easy fix.​​​​​​​
  #30
Old 03-05-2022 | 08:36 PM
Franklin2's Avatar
Franklin2
Quick Reply: F250 Airbag light blinks and stays on!
