antifreeze leak/cyl head
Old 01-23-2006 | 01:19 PM
ksvtwin's Avatar
ksvtwin
Hello, i've got a '93 ranger with a 4.0 V6. it just turned over 100,000 miles and has an antifreeze leak coming from behind the drivers side motor mount. I suspect a head gasket or cracked head. it's using a bunch, about 1 gallon per week. no water in the oil or anything. Does anybody know if these engines were prone to cracked heads or head gasket leaks? appreciate any advice I can get. Thanks, Kent
Old 01-23-2006 | 03:45 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
I have read of a few isolated incidents of a leaking head gasket on the drivers side of the 4.0 and susbequent coolant loss. The problem is about as far from common as you can get.
Old 01-23-2006 | 08:30 PM
Rockledge's Avatar
Rockledge
That would be a pretty big leak for a headgasket, you should also consider a possible leaky lower intake gasket.
This article might be of some interest to you, particularly the TSB that's attached at the end:
Replacing the 4.0L Upper Engine Gaskets
Old 10-10-2006 | 11:38 PM
dogjack's Avatar
dogjack
sounds like a freeze plug I just changed mine
Old 10-11-2006 | 10:03 AM
irocknrol2's Avatar
irocknrol2
If you are not experiencing any rough engine issues, then its probably not a head gasket, more probably a rusted freeze plug. If the anit freeze has not been regularly changed it has a tendency to rust things out.
upurz1
1997-2006 Expedition & Navigator
03-31-2016 11:29 AM
kirby1111
1978 - 1996 Big Bronco
15
03-08-2016 04:39 PM
rmalottwtes30
09-19-2011 12:27 PM
blueovalboy86
06-10-2007 09:23 AM
swirk
05-03-2003 09:31 AM
