1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
how do i take off plastic cover for steering column
Old 10-24-2005 | 08:44 PM
OfficerDangle's Avatar
OfficerDangle
99 f250 auto and i need to get the plastic housing off the steering column so i can get to some wires inside the shifter lever, how do i get the housing for the key off and the steering wheel tilt lever off? the whole housing needs to come off so how do i remove it.
Old 10-24-2005 | 09:02 PM
EnviroCon's Avatar
EnviroCon
Unscrew the tilt lever, it may be a little tight, but it does unscrew. Then look up underneath the bottom of the plastic housing. You will see screw holes. Shine a flashlight up in the holes to see the screws, there are 4 holes but only 3 of them are actually screws. Unscrew them and the lower portion of the housing will come off. Look up at the bottom of the ignition switch and you will see a little ball. Place your key in the ignition switch and press up on the little ball and the switch will come out.
Old 10-25-2005 | 07:02 AM
IB Tim's Avatar
IB Tim
Site Administrator
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 09-13-2024 | 02:03 PM
ShannoC73's Avatar
ShannoC73
1st Gear
What tool did you use
Airslot
08-29-2011 06:56 PM
guffey
06-01-2006 11:21 AM
Tjackson
05-31-2006 06:04 AM
haamezzed
06-12-2005 05:49 PM
gg1519
04-01-2005 04:00 PM
Quick Reply: how do i take off plastic cover for steering column
