Hooking up high idle w/upfitter switches
#62
in the last few days we've wired up 4 f350's without a problem except one. it's a 06 with manual trans and a service body with picker. he had already used switches 3&4 so I used #1 (30amp) and used the bcp ( purple ) wire because the orange wouldn't work ( because of the service body?). it idled up to 1400 rpm right off the bat and held it for almost an hour, then he found it idling up to 2000rpm. why is this? too high of amp on switch? or is there something I missed? also, on the 2009 we're working on, I can't find the upfitter harness. any secrets here?
#63
Second, the purple wire is for Battery Charge Protect, and will idle up to 1,200 or higher to protect the battery. If for some reason the battery is losing charge, like a marginal alternator for example, or perhaps something drawing a lot of current, then the RPM will go higher to maintain the charge. Was there something in use on the truck? Like lights or inverter?
#65
#66
I just finished this project on my 09 F350. I used upfitter 4 and spliced into the BCP (battery charge protect) wire. I plan to use it when running high electric loads like my electric winch and other things when connected to my race car trailer. It was as easy as connecting two wires. Nice! Might try using it to warm up the truck on a cold day, too.
#67
#71
#74
#75
Jimmy, I don't have remote start, but since no one jumped in I will reply. I know there have been guys with RS who have done the high idle. I don't think there are any problems with that. You just have to make sure you leave the truck in Park with the parking brake set. Once the truck starts, after a short delay, it should go high idle.
