Closed knuckle Dana 44
I just waited a week for my 75 closed knuckle dana 44 spindle bushings order to arrive at the local Ford dealership. I walked in to check on my order only to find that Ford cannot deliver the part... reason given was "NR - not replaceable" ... Obselete?? I was thinking that I might find a roller bearing with the same ID and OD to replace the brass bushings that are pressed into the back of the spindles. Where would I get parts for a closed knuckle Dana 44. Can I order the parts directly from Spicer? I already bought the trunion bearings, so if I can get some spindle bushings that aren't carved out I'll be back on the road. If I can't find parts I'll make them, but only if it comes to that!
Adam
1975 F250 4x4
http://atc.250x.com/trucks/1975ford/1975ford.html
1970 F250 4x4
http://atc.250x.com/trucks/1970ford/1970ford.html
Adam
1975 F250 4x4
1970 F250 4x4
Adam,
What part of the country are you in? I have the HD 44 out of my '74 sitting in my carport after replacing it with a '77 disc-brake version, and haven't decided how to dispose of the original. It had about 110K miles on it, pretty meaningless, because who uses the front axle engaged that much? Anyway, if you or anyone else in shouting distance of Central Oregon could use it, plus the original power steering ram, valve, and hoses, I'd sure like to get it out of my way!
Steve
Steve
Hey, thanks for the offer, I surely would like to install an HD, though I only have 33" tires so it's not like I'm going to break anything.... and I'm pretty easy on the old truck. I live in New Hampshire though, so it's unlikely that I'd be out in Oregon anytime soon.
Adam
Adam
yes dana spicer still makes them ill look in my shop and get you a part # i have a 75 with that axle and i replaced them about 2 years ago you wont get them from a dealer there to busy trying to sell that new junk also to the guy needing a axle i have one and lots of parts
robo@pathwaynet.com
robo@pathwaynet.com
ZarK-eh
24
08-02-2015 12:28 PM
ZarK-eh
12-18-2014 12:59 AM
NateTheGreat
18
10-23-2013 03:57 PM
