Cleaning MAF & IAC
Old 08-16-2005 | 05:54 PM
tinkybug's Avatar
tinkybug
Smile Cleaning MAF & IAC
1997 Ford Explorer SOHC 4.0 XLT 4WD. CEL code PO174 for quite a while and engine stutters @ stoplight once in a while. It recently died while at stoplight. This is my girlfriend's vehicle and I'm going to clean MAF & IAC. I could not find CRC QD Electronic Cleaner. I did find Radio Shack Contact/Control Cleaner and Lubricant. The "Lubricant" portion of this concerns me. I would appreciate it if I could have some comments on whether this stuff is okay to use or not.
Old 08-16-2005 | 07:35 PM
maa139's Avatar
maa139
I wouldn't use it. I've used throttle body cleaner with good results. I've also been warned against brake cleaner on the MAF. Apparently there is something in brake cleaner that will leave a residue that will eat away at the filaments.
Good luck.
Matt
Old 08-16-2005 | 09:46 PM
tinkybug's Avatar
tinkybug
Thanks for replying Matt. That little voice inside told me this stuff was trouble. I'll search until I can find the CRC QD Electronic Cleaner.
Tinkybug
Old 08-16-2005 | 09:54 PM
vicv's Avatar
vicv
I've used carb cleaner on both maf & iac. And a little wd40 afterwards on the iac.
Old 08-17-2005 | 03:06 AM
Jharger's Avatar
Jharger
Carb cleaner or brake is OK on MAF - I never had any problems. Brake cleaner dries faster.
Old 08-17-2005 | 07:18 AM
bulldog3531's Avatar
bulldog3531
you should be able to find Electronic Cleaner at auto zone or some other auto parts store.
Old 08-17-2005 | 02:18 PM
tinkybug's Avatar
tinkybug
Yes, I found the CRC QD Electronic Cleaner at a Schucks store here.
Old 09-03-2005 | 01:27 PM
tinkybug's Avatar
tinkybug
I cleaned the MAF & IAC with the CRC QD Electronic Cleaner. The MAF looked pretty clean when I initially got it out. The IAC was full of carbon. I was able to pull the black **** off the IAC and the small filter came out in 3 parts(shud have only been 1 part). Sprayed everything and then let it dry. Reinstalled it (just put that small filter back in,too) and that CEL went away and has not come back on. Hurray!! So this forum saved us the frustration of dealing with a Ford dealer + money. I had checked out a Haynes repair book from the library. I learned a lot about this vehicle & others by reading a lot of postings all the way back to the beginning several years ago. At least I have some knowledge now. It would certainly be nice if all posters would come back on the forum after they solve their problems and let all know what the solution was. Knowledge is power!! It's amazing what you can learn from the different forums and by referencing Google/Yahoo.
Old 09-05-2005 | 01:52 AM
Jharger's Avatar
Jharger
You go it tinky. knowledge is power. the information age is awesome. more people need to share their successes with us so the rest can prosper. I love being able to help people. And I relish that others can help me when needed (like Mrshorty). Congrats on sidestepping the dealers!
tonyford
Escape & Escape Hybrid
03-02-2013 05:40 PM
xc4jokestomper
26
07-28-2010 09:58 PM
kye
1997 - 2003 F150
11-05-2009 08:36 AM
BigMacZack
12-04-2003 11:24 PM
e_no_g
12-11-2002 03:03 PM
