1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Bilstein Shocks
Old 04-12-2005 | 09:58 PM
03 SuperDuty FX4's Avatar
03 SuperDuty FX4
Bilstein Shocks
Today I installed HD Bilstein Shocks Front-BE5-2818, Rear-BE5-2819. I took out the ranchos and the boot was to the top but when I tried to install the bilsteins they would not go on with the boot to the top. They wouldn't go on because the top mount has that metal sleeve as well as the mount on the shock with the boot up. So I put the boot down, does this make a difference on the way the shock will perform? Same problem with the fronts. Also are the new shocks supposed to lift the truck, or will it settle down once they are broken in?
Old 04-12-2005 | 10:02 PM
basstardo's Avatar
basstardo
The Bilsteins are supposed to be like that. Enjoy 'em!
Old 04-12-2005 | 10:05 PM
03 SuperDuty FX4
Thanks for the quick reply, was just wondering becuase I read that the boots go up.
Old 04-12-2005 | 10:40 PM
cc322's Avatar
cc322
Thumbs up
You will love the shocks on that truck good choice imo
Old 04-13-2005 | 03:50 PM
SAYERS's Avatar
SAYERS
bilstein shocks
I am getting ready to do the same to my 2003 f350 fx4, when you say the boot went down. do you mean the blue plastic cover. Or to say it differently did you invert the shock ?
Old 04-13-2005 | 06:35 PM
EnviroCon's Avatar
EnviroCon
Yes. The Bilsteins go rod end down, cylinder side up. So when the shocks mounted, the rubber boot that covers the rod will be closest to the axle, while the cylinder will be on the shock mount attached to the frame. This is the case both front and rear.
