Fuel tank?
Old 03-08-2005 | 06:57 PM
Culvert's Avatar
Culvert
Question Fuel tank?
I have a 91 F250 S/C long box w/dual tanks. the rear tank leaks when over 1/2 full.
Will a tank from a 90 F150 SB work? are they close enough other than capacity?
Old 03-08-2005 | 08:17 PM
vman's Avatar
vman
Pretty sure all the rear tanks are the same, its the fronts that are different,and even those can interchange.
Old 03-09-2005 | 07:22 PM
alphacarina's Avatar
alphacarina
The rear tanks can be either plastic or steel - Either can fit (with the correct straps) but the FDM is different for the two, so you wouldn't be able to take the fuel pump/gauge sender out of a plastic tank and put it in a steel tank
Don
Old 03-11-2005 | 03:45 AM
midlf's Avatar
midlf
Check the replacement tank closely for rust if they use salt in your part of Canada. Your leak is probably due to rust, most likely under a strap or at a seam.
