1978 - 1996 Big Bronco
t-case
Old 03-02-2005 | 04:54 PM
racin883r's Avatar
racin883r
t-case
lookin for a borg warner 1356 t-case manual shift....any one got one?
Old 03-02-2005 | 06:38 PM
kameronth's Avatar
kameronth
I don't have a spare one but they are not all to hard to rebuild. If you look in my gallery you can see some pics of my rebuild.
Old 03-02-2005 | 08:06 PM
dwoodler's Avatar
dwoodler
I just finished rebuilding mine. It cost me about $150 for the kit (brgings and seals) but as soon as you add forks or gears the cost climbs. Also, most of the guts out of the electric shift t-cases are the same as the manual ones.
Don
Old 03-03-2005 | 01:08 AM
greystreak92's Avatar
greystreak92
Originally Posted by dwoodler
Also, most of the guts out of the electric shift t-cases are the same as the manual ones. Don
Agreed. My research has led me to believe that the major difference between the manual and the electronic versions is the casing. Most of the innards are interchangable.
Old 03-03-2005 | 03:23 PM
dwoodler's Avatar
dwoodler
If you look closely the cases are exactly the same with just the holes drilled out for the right lever / or electric parts. I've got my spare manual case sitting here now. Just need to pressure wash it out cause it's full of crud. Rebuilding the T-case is fairly straight ahead as there are no really identical pieces. The snap rings are the same. The only trouble that I had was the split ring on the input from the transmission. There are some nice external snap ring pliers that are needle nosed with grippers (like on the inside of slip-joint pliers) that work really great here. I ended up playing around with a pair of picks for 20 minutes the first time. lol If you run into any snags give a shout back here. Good luck.
Don
Old 03-03-2005 | 04:42 PM
greystreak92
Don,
Any chance you might know a good source for a manual 1356? I am dumping the electronic one ASAP but would like to get my hands on either a good used or reman. manual unit. I would also need the shift linkage/lever, boot etc. I know a couple of places but figured I'd ask someone who has obviously done the swap or at least knows both T-cases fairly well.
Old 03-03-2005 | 08:24 PM
kameronth's Avatar
kameronth
Originally Posted by greystreak92
Don,
Hmm, I got lucky because my truck came with the manual one. I have seen some on ebay but just like everything else you would be taking your chances. Most shops want a $grand or so for one. Your best bet would probably be to get one from the junk yard and rebuild it yourself, very simple rebuild Also you could get the boot and shift rod off the junk truck.
Old 03-03-2005 | 09:03 PM
93bronc84's Avatar
93bronc84
got one at my junk yard for $400 I can send it out if ya want . I was looking to get it for myself but then I fixed up my auto and cant seem to fix something that aint broke. Let me know if I can do something for ya, I have found a handful of broncs in the yard in just the last few months
Old 03-03-2005 | 11:59 PM
justshootme84's Avatar
justshootme84
I have a used m.s. B-W 13-56 from my 88 Bronco listed at superford.org.
Old 03-04-2005 | 04:19 PM
dwoodler's Avatar
dwoodler
After rebuilding mine, there is no way that I would buy a reman unit. The unit is straight ahead to tear apart and rebuild. My Haynes had a good explanation and the local tranny shop was helpful. As for getting a good used one ... looks like you have several to choose from. Let me know how installing the linkages goes for you though. That's the only thing I thought might be a pita when swapping to a manual t-case. Thanks.
Don
Old 03-05-2005 | 03:00 AM
greystreak92
Yeah, I was a littel concerned about it myself until I pulled the carpet back in mine and realized the hole in the floor for the shift linkage and boot are already there just need to pull the plate covering the hole.
