converting from 302 carbueration to 302 fuel injection
I currently have an 84 ford f-150 with 302 that is carbuerated and i just recieved a complete 89 e-150 van with 5.0l fuel injection as my old 84 engine is getting tired i am considering refreshing the engine from the 89 and swapping it into my 84. I have the complete donor vehicle so I am guessing I have all the parts I would need to do this swap but I am unsure exactly what I need to use from the donor vehicle to completely swap the engine and fuel injection system into the truck. I normally do alot of trail riding and hill climbing so I was thinking that the fuel injection would keep me from stalling out during high angle or off camber situations that I cureently experience with the carbuerated engine. Any helps or tips from others that have performed this same type of swap would be helpful.
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
302, 84, applications, carbuerate, carbuerated, cfm, choosing, converting, efi, f150, ford, fuel, injected, size, turbo
