Oil & Lubrication
E40D Fluid?
Old 02-08-2005 | 02:21 AM
50stang's Avatar
50stang
E40D Fluid?
I am about to drop the pan on my '98 Expedition 5.4 with the E40D Tranny. The book says it uses Mercon fluid and the dipstick also simply says Mercon on it. I was thinking when I ran and purchased the fluid that it was Mercon V until I took a closer look at it. However, the fluid I purchased was Valvoline Mercon V for '96 and newer Ford's. It says on the back of the bottle that it meets both Mercon and Mercon V requirements? Is this ok to mix with the straight mercon that is in the transmission from the factory?
Thanks!
Old 02-08-2005 | 07:51 AM
Rockledge's Avatar
Rockledge
The Valvoline dual-rated fluid should be OK for your E4OD, since it requires Mercon.
If your tranny required Mercon V, then I would have advised against the dual-rated ATF and suggested a straight 100% Mercon V fluid.
Old 02-08-2005 | 08:48 AM
Casey's Avatar
Casey
Dual rated MERCON and MERCON V fluid is NOT good for an E4OD. You're looking at a shortened life if you run that fluid.
Run what the dipstick says. MERCON fluid.
Old 02-08-2005 | 09:01 AM
cmlind's Avatar
cmlind
My Taurus owners manual says dual rated fluids are ok for Mercon V. I am confused with it, so I stay with a single rated fluid. I would recommend taking the dual rated back and get some Mercon. If you have the E4OD, it is finicky and does like regular Mercon.
Old 02-08-2005 | 12:40 PM
TallPaul's Avatar
TallPaul
There is a never ending debate on this single rated vs dual rated Mercon thing. I sure wish there was a definitive answer. I am runing Redline D4 (dual rated) in an A4LD, but I was scared to do it to my 1990 E4OD as I heard the E4OD is the critical one for fluid type tollerance. So I am running Mobil 1 Mercon ATF in the E4OD. But then the guy at Redline says that's just Ford's way of getting you to buy their fluid. Who knows?
Old 02-08-2005 | 01:52 PM
aurgathor's Avatar
aurgathor
When I last time checked ATF prices, comparable fluids of different types (i.e. F, Mercon, etc. of a same brand) all had the same prices, so there's no reason to go with a different type of ATF. Of course, if some company doesn't make all the fluid then that might be an issue.
Old 02-08-2005 | 02:15 PM
Rockledge's Avatar
Rockledge
I can understand how a transmission might prefer one type of fluid over another. A search of this forum would turn up a few previous posts by me describing how disappointed I was with my Ranger's 5R55E tranny after it had been filled with Valvoline's dual-rated Durablend ATF. When I flushed the dual-rated stuff out and put in straight Castrol Mercon V (recommended and approved by Ford), the 5R55E's performance improved significantly.
IMO it's the dual-rated fluids that are helping to confuse the issue. The manufacturers of these products claim they "exceed" both Mercon AND Mercon V specs. Yet many times these "hybrids" just don't work as well as advertised.
In any case, if people say nothing but regular Mercon for the E4OD because that's what it prefers, I can easily go along with that.
Old 02-08-2005 | 02:51 PM
50stang's Avatar
50stang
So dual rated Transmission fluid in general is not a good idea from what I see in the posts? What about the standard Dexron III, Mercon dual rated fluid? That is about the only thing you really see at stores around here. If I wanted straight Mercon only I would end up probably having to get it at a Ford Dealership.
Also... what do you guys think about Lucas additives for the Transmission that "control heat" and "prevent wear" and things like that? Is there any truth to a transmission additive like that? Or would my E4OD be picky about that kind of stuff in the fluid as well?
Old 02-08-2005 | 03:43 PM
Casey's Avatar
Casey
Dexron III/MERCON fluids are fine. The specs for DEXRON III and MERCON are so close that it is almost impossible to make a fluid that meets one but not the other.
On the other hand MERCON and MERCON V are very different, and there is something in MERCON V that causes problems down the road in E4ODs and 4R100 transmissions.
Old 02-08-2005 | 04:49 PM
csramsey640's Avatar
csramsey640
Here is my e4od input. As stated above they are very picky on fluids. I do not agree with dual rated fluids, but to every person thier own. The e40d likes a good quality Mercon fluid. The best way I know of to tell is either shake the bottle of pour a little bit.
Wal-Marts Mercon fluid, is very thin, and the 2 vehicles i have seen it in, shifted hard. If you shake it its thin, and when you pour it out its not as red as some better fluids. I work at a Ford garage and use Motorcraft and my tranny shifts great with a pile of miles on it. When poured the fluid seems thinker with a LOT more red color. Napa or Valvoline is the same way, as are Pennzoil. Those are ones Ive used. So it doesnt matter what name is on the bottle, if its a good grade, it should be fine for that tranny.
Old 02-21-2005 | 08:33 AM
brian_06328's Avatar
brian_06328
is anyone running, or have an opinion on running, synthetic ATF in the E4OD. I have a '95 F250 w/460 & E4OD. If so, what's a good brand to look at?
Old 02-21-2005 | 08:43 AM
Casey's Avatar
Casey
Use Mobil 1 synthetic ATF. It is MERCON and not MERCON V, and that's what the E4OD needs.
Jamesmccowan
1983 - 2012 Ranger & B-Series
07-07-2017 02:46 PM
blue84f250
12-29-2013 11:54 PM
AmmoDawg
1997-2006 Expedition & Navigator
01-08-2013 10:26 AM
tonyford
Escape & Escape Hybrid
11-30-2010 12:21 PM
polar88
05-01-2005 04:41 PM
