update on rough idle/bad mpg
hi guys,just an update.went back to ford yesterday.They checked computer they had installed last weak.It apparently showed the air temp sensor not working correctly.
What do you think? Is this a true possibility for idle and bad mpg??
They will install new on next weak,hope they are right.I will keep you all posted with the results.
