aluminum extension housing SEAL
Old 12-22-2004 | 09:23 PM
greengobblin's Avatar
greengobblin
Question aluminum extension housing SEAL
Hey Guys! I Have A 92 F-150 With A T-18 B.w. Trans With 4x4 1356 B.w. Transfer Case . Ineed To Know If Anyone Knows The # Of The Seal That Is In The Extension Housing That Keeps The Trans. Oil In The The Trans. Mine Is Missing, Some One Must Have Taken It Out Before I Bought The Old Girl .i Haven't Had Any Problems With The Trans Or Clutch Since 95 When I Bought It,so Now I Found Out The Seal Is Gone And Ford Can Not Tell Me What Seal Goes In There Unless I The Old Seal ! Any Advice? Thanks!
Old 12-27-2004 | 06:18 PM
greengobblin
Question
Ok ! Does Anyone Know Where I Can Get A Seal Kit For The Extension Housing? THANKS!
Old 12-28-2004 | 02:27 AM
Overkill-F1's Avatar
Overkill-F1
I recently replaced the rear seal on my transfer case, '90 F150, 4x4, 302, AOD, BW1356. I used a 'Chicago Rawhide' seal # 18687. ...Terry
Old 12-28-2004 | 07:52 PM
fordman300's Avatar
fordman300
is your truck a 4 or 5spd. im guessing 5spd and a m5od because i dont think the t18 used an aluminum housing. if i remember right when i replaced the rear tranny seal in my m5od i had a bitch of a time finding one even with the old one. the first one they ordered was the wrong one and then it took 5 days to get the right one its metric if i recall. if i were you i would get out the mics and spec the inside and outside diameter and width and go to your real (not autozone or any other autoparts store) local bearing distributor and give them the sizes they should be able to get u the right one.
Old 01-08-2005 | 05:32 PM
greengobblin
Smile extension housing
nope! mine does have A t-18 borg warner 4-speed with alum. extension housing. it was special ordered that way . the ford dealer says that it didnt come with that trans every time i go to get parts. thanks!
rock2610d
09-26-2015 10:44 PM
markeyd
13
06-18-2015 01:56 PM
sonny1965
05-30-2014 10:43 AM
Robert Vandervennet
10-28-2012 04:55 PM
bc56845
02-13-2011 11:55 PM
