oil in air cleaner
Old 12-10-2004 | 06:24 PM
78_ford_F150's Avatar
78_ford_F150
oil in air cleaner
i just changed the oil in my truck 400 motor and when i took the ari cleaner off there was oil in it the bottom of a stock air cleaner its full whats doing that
Old 12-10-2004 | 06:28 PM
Bill_Beyer's Avatar
Bill_Beyer
Crankcase vent. Check you PCV valve to make sure it's working correctly. Otherwise you have a significant amount of blowby.
Old 12-10-2004 | 09:24 PM
78_ford_F150
i put a new pvc valve in the oil cap, ill check the passenger side and if i do have a significant amount of blowby what do i do to fix it
Old 12-10-2004 | 09:26 PM
85e150's Avatar
85e150
Is your pvc in the cap or pushed into a grommet on the valve cover? The pcv is supposed to prevent oil from getting through. You got any drain down issues?
Seen a lot of them back in the day. What a mess. Good luck.
Old 12-11-2004 | 09:27 AM
Bill_Beyer's Avatar
Bill_Beyer
Excess blowby is generally a sign of worn out rings. In extreme cases it can actually pressurize the crankcase to the point that oil will find the easiest way out of the system, usually through the dipstick.
The liquid oil you're seeing in your air filter housing is vaporized oil that has made its way up through the vent and condensed in your air cleaner. The PCV system is supposed to utilize the vent to pull fresh air into the crankcase as it pulls the blowby gases, which are very volatile, out and into the intake to reburn them. Obviously when the engine is shut off the "positive" portion of the PCV system quits functioning but the "venting" portion doesn't so hot oil fumes drift up through the vent into the air cleaner and condense in the cooler atmosphere.
If your PCV system is being overwhelmed by the amount of blowby then you may simply have a worn out engine. Other causes could be an engine which is running too rich and pumping unburned fuel into the crankcase which thins the oil and makes it easier to vaporize as well as cheap aftermarket rocker covers which aren't baffled.
Old 12-11-2004 | 12:43 PM
78_ford_F150
the motor was just rebuilt 10000 kms ago im going to check the PCV system
Old 12-15-2004 | 09:59 PM
78_ford_F150
i replaced the pvc stuff and no change so over x mas im going to pull the motor and rering it again
Old 12-15-2004 | 11:17 PM
Torque1st's Avatar
Torque1st
Posting Legend
Make sure the PCV system is working b4 you pull the engine.
Old 12-16-2004 | 08:00 AM
M.Stephens's Avatar
M.Stephens
Excellent responses, geez this is just like being in auto mechanics class.
Bill thanks for a comprehensive explanantion.
Old 12-16-2004 | 09:47 AM
78_ford_F150
how do u check to see if the pvc system works. i mite have to pull the motor anyway, when i listen the exhaust on the driver side it sounds nice, but on the pass side it pops. it sounds like a burnt or chiped vealve. so im going to do a compressin test and if theres a differns im going the pull off the head and if its chiped the motor is necked. if i have to pull the motor and rering it would it be worth puting flattop pistons in at the time and what is the cost
Old 12-19-2004 | 07:45 AM
Torque1st's Avatar
Torque1st
Posting Legend
You need a service manual. Simple diagnostic tests are listed in them with directions. If you don't want to use a service manual any competent mechanic can perform diagnostic tests on your engine.
Old 12-21-2004 | 05:09 PM
78_ford_F150
i went an seen a mechanic and he said the rings didn't seat and i mite have brock one thats wath chiped the vealve
